Turn signal light issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by Buexdreux, Nov 16, 2015.
  1. Nov 16, 2015 at 3:51 PM
    Buexdreux
    Buexdreux [OP] Well-Known Member
    2002 White Tacoma 3.4L 4x4
    Nothing yet
    I have an 02 with a brand new electrical problem, my rear right turn signal decides when it wants to work. At first I thought the light bulb needed to be replaced, so I changed it and that fixed the issue for about two days then it started all over again. The turn signal acts like the light bulb is bad, but its good and the funny thing is it works when it wants to. Is this some relay problem? The wiring is good and the bulb is in the socket tight and has good contact. This little issue is driving my OCD crazy!
  2. Nov 16, 2015 at 4:37 PM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    My 98 has the exact same problem. I haven't done it yet but I was going to replace the connector back there. If I turn the signal on and reach under there and jiggle the wires by the connector the blinker comes back on. It's either a lose wire or the connector contacts are corroded enough to not contact well.
  3. Nov 17, 2015 at 4:07 PM
    Buexdreux
    Nothing yet
    I'm going to recheck all of the wires sometime this weekend when I have a chance. I hope it's something as easy as that and not some gremlin that I'll never find.
