Turn Signal \ Marker light and Theater \ Courtesy Mud lights Controller
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by mechanicjon, May 4, 2017.
  1. May 3, 2020 at 10:10 PM
    #41
    mechanicjon
    mechanicjon [OP] They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Then your outputs to your theater,/puddle lights
  2. May 3, 2020 at 10:11 PM
    #42
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    i'll dig and see what the wiring looks like behind the fuse box. should just be contained to the one connector.. maybe a 2nd.
    mechanicjon[OP] likes this.
  3. Sep 24, 2020 at 10:45 PM
    #43
    Madjik_Man
    Colorado Front Range
    Forgive my ignorance but I don't know how this works, I just read on page 1 or 2 about having the stock corner/marker lights also act as a turn signal. I'm about to replace my grill, which includes removing the spliced in wires to the corner lights so the previous owner could have raptor lights in the grill.
    How exactly does this box of yours work? And how would I wire it in to have my corner/marker lights also function as turn signals. And would I still maintain the stock turn signal function?
    Thanks in advance.
  4. Sep 25, 2020 at 5:47 AM
    #44
    Akkording
    Akkording Well-Known Member
    Pete
    Houston
    03 +300k Still Truckin, 2012 4Runner
    Please PM me your total ship price and paypal address
  5. Sep 25, 2020 at 11:04 AM
    #45
    mechanicjon
    Jon
    Scottsdale Arizona
    Yes you stock turn signals work like normal. It uses the same bulb as turn signal and marker light. It does require a new wire be run to each turn signal to controller box.
  6. Sep 25, 2020 at 11:05 AM
    #46
    mechanicjon
    Jon
    Scottsdale Arizona
    Which function do you want?
    I've designed and built a controller for using a single light as a turn signal and marker light.
    Also incorporated a time delayed and dimming rate for theater, mud, exit lights or interior lights.
    3 versions available:
    1. Turn signal and theater lights $80.00+ shipping
    2. Turn signals only $45.00 + shipping
    3. Theater lights 45.00 + shipping
  7. Sep 25, 2020 at 11:42 AM
    #47
    Madjik_Man
    Nice. Is post #26 showing me how to wire it all up? And you just bolted the controller under the lower dash, correct?
    Thanks for the answers.
  8. Sep 25, 2020 at 1:34 PM
    #48
    Akkording
    Pete
    Houston
    All Lasfit amber leds, currently using modded 1157 sockets in corners and 3157 sockets in bumper. Just purchased but haven't installed led relay from Amazon, will that effect the flashing function from your control unit. I plan on installing rear turning Lasfit led ambers.
    My ultimate goal is to run DRL both pairs always on in the front and flash when I signal.
    Aim running
    I guess turns only.
    All Lasfit amber leds, currently using modded 1157 sockets in corners and 3157 sockets in bumper. Just purchased but haven't installed, led relay from Amazon, will that effect the flashing function from your control unit? I plan on installing rear turning Lasfit led ambers well.
    My ultimate goal is to run in DRL mode both pairs always ON and flash when I signal.
    I'm running smoked housings in the corners and bumpers
  9. Sep 25, 2020 at 3:19 PM
    #49
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    You don't need relays with any modern switchback controller
  10. Sep 25, 2020 at 6:08 PM
    #50
    mechanicjon
    Jon
    Scottsdale Arizona
    Are they switchback led lights? either way you'll need the led flasher.
  11. Sep 25, 2020 at 8:16 PM
    #51
    Akkording
    Pete
    Houston
    Non switchbacks, all amber leds, I'm going more for the JDM style.
    Led flasher? Meaning I do need to install the led relay switch?
  12. Sep 25, 2020 at 8:26 PM
    #52
    Akkording
    Pete
    Houston
    This is what I bought and installed.
    https://www.tacomaworld.com/threads/how-to-replace-your-turn-signal-relay.518338/
    So you are saying I'll need this relay in conjunction with your controller, I figured for my rear 1156 turning to work without hyper flashing since the lasfit ones I have are not canbus error free model
  13. Sep 25, 2020 at 8:53 PM
    #53
    Akkording
    Pete
    Houston
  14. Sep 25, 2020 at 10:29 PM
    #54
    mechanicjon
    Jon
    Scottsdale Arizona
  15. Sep 25, 2020 at 11:30 PM
    #55
    Akkording
    Pete
    Houston
