Turn signal mirrors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mcclintick_c, Aug 10, 2015.
  1. Aug 25, 2015 at 10:55 PM
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Only way to know for sure is to check the white harness. Pink wire should be positive and white wire ground. Turn your turn signals on and see if the pink wire gives a 12v pulse
    GMAN62465 likes this.
  2. Nov 14, 2017 at 7:56 PM
    000doodie000
    000doodie000 Well-Known Member
    J
    2015 Taco TRD Off-Road
    Many and always modding Wheels Suspension lift Armor Electrical gadgets etc...
    now that its been a few years.. still like the mirrors? if so, do you have the part number?
  3. Nov 16, 2017 at 6:51 AM
    CITY TACO
    CITY TACO Well-Known Member
    Greater New Brunswick
    15 TRD Barcelona Red
    I would not bother with them if the are TRC brand or some other Chinese brand. They might look the same and work but if they screw up or you break the mirror, good luck in finding one as the mirrors are smaller then a regular Tacoma and the backing plate is not the same so nothing fits you have to buy another whole assembly. Figured this out when I bought a pair and wanted to heat them. Mirrors are stuck to the backing plates with a combination of hot glue and RTV and you will break the mirror trying to remove it. Your original mirrors have a shell over them that comes off and you should see the place where the light bar goes. Now this light bar is the same for the 2015 and down Tacoma sport, 2009 to 2012 RAV4 and the same years Sienna. Toyota wants $130 a piece for them up here in Canada but the junk yards are full of them for $10 a piece. Toyota sells the sport mirror cover with the cutout in your trucks color for around $60. Then you have to run wiring back to connect them up. Worked for me.
  4. Jan 22, 2018 at 3:50 PM
    Five_Zone
    Five_Zone New Member
    2010 Black Tacoma TRD
    I just bought the 2012 Factory side view mirror lights (before reading all these feeds). I have a 2010 TRD tacoma. Is there anyway to wire the turn signal to make it work? The mirror adjust and that plug and play works fine. Just need to know how to wire the signals to work. If not they are going back for sale.
  5. Jun 19, 2020 at 8:36 PM
    GMAN62465
    GMAN62465 Well-Known Member
    Gary
    Fairfield County, Connecticut
    2015 White DCSB Off-Road Plus
    Which white harness and where is this located??
    Any pictures?
  6. Jun 20, 2020 at 9:34 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
