Turn Signal Off Reminder
Discussion in 'Lighting' started by mcgiiver, Apr 6, 2010.
  1. Apr 6, 2010 at 5:52 AM
    mcgiiver
    mcgiiver [OP] Well-Known Member
    Princeton, NJ
    2009 Access cab 4x4, 4 cyl, stick
    Aftermarket Driving Lights, Hidden Hitch, Removed rear headrests, Side protective moldings, vacuum gauge, Scan Gauge, Leer cap.
    Any ideas how to make a turn signal off reminder buzzer or beeper. I have my Scan Gauge mounted where it blocked the dash indicators for the signals, so I would like an audio reminder. I am thinking about a piezo buzzer from Radio Shack, but don't know quite where to hook it up to. Any ideas?
  2. Apr 6, 2010 at 3:26 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Yes, but it is not easy. It would be a hell of a lot easier to just move the scan gauge.
    If you're unwilling to do that, then you would need a set of buzzers. You would have to splice one buzzer into the right turn signal wire and the other buzzer into the left turn signal wire.
    Specifically you would be tapping into the wire that sends the signal to light each turn signal lamp on your dash.
    This method would be necessary to avoid the complication that DTRL presents us with.
    DTRL provides us with two modes of operation. For example.
    Daytime: Lowbeams off = DTRL = ON (constantly)
    Nighttime: lowbeams on = DTRL = OFF.
    Also, using LED's instead of a buzzer would probably be a better solution.
    Attached is the wiring diagram for the 2007. It is not identical to the 2009's but it should give you a good idea.
    Also, the turn signal flasher relay is accessible from under the driver side dash it is attached to the body ECU/fuse block. It is the closest relay to the steering column.
  3. Apr 7, 2010 at 9:14 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    if you do the buzzer thing, think about this...every time you signal you will hear that thing...im guessing it will get old real quick!!
  4. Apr 21, 2010 at 4:59 PM
    mcgiiver
    Princeton, NJ
    That's exactly what I want, to hear it everytime the turn signal is on.
  5. Apr 21, 2010 at 5:02 PM
    WTtoolman
    WTtoolman Facial bones colapse as I crack your skull in half
    William
    Omaha, NE
    2006 Access Cab 4x4 TRD SWB
    5100s at 0, eibachs, 2" toytec AAL,, Moto Metal 951b, BFG A/T
    Don't do it!!
  6. Apr 21, 2010 at 5:03 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    You mean like that clicking noise that it already makes?
  7. Apr 21, 2010 at 5:06 PM
    lookylookitzadam
    lookylookitzadam Retrofit Club!
    Adam
    San Diego
    07 DC OffRoad
    exactly what I thought.
  8. Apr 22, 2010 at 4:04 AM
    mcgiiver
    Princeton, NJ
    I have installed it on my motorcycle also. its especially helpful with a helmet and ear plugs on. I frankly don't care who it annoys as long as it helps me drive safer.
    The relay clicking noise on my 2009 truck is not loud enough to notice, especially over the radio. My older truck was better, in fact I think they made that clicker loud on purpose.
  9. Apr 22, 2010 at 4:18 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Where is your scangauge? I have mine mounted on the steering column and I can still see the blinkers.... I'm 5'6"
    Is your steering column the whole way up? (you must be tall ?)
  10. Apr 22, 2010 at 1:08 PM
    mcgiiver
    Princeton, NJ
    I have mine mounted in the same place, but I am 5'7" but run my steering wheel all the way up and move it depending on my seating position. The buzzer works great, even w/o the scan gauge , I forgot to shut off the turn signal many times.
  11. Apr 22, 2010 at 4:22 PM
    Suroit
    Suroit Active Member
    Jack
    New-Brunswick Canada
    Tacoma TRD SR5
    Front Susp., Tires & Mags
    you don't need 2 buzzer... use the same one... too easy ... i have one buzzer in my Tractor Trailer..... and in most of all Tractor Trailer...
  12. Apr 22, 2010 at 5:58 PM
    mcgiiver
    Princeton, NJ
    That's right, one buzzer, two diodes.
