Turn Signal Problems
Discussion in 'Technical Chat' started by Blumpkinson, Sep 2, 2009.
  1. Sep 2, 2009 at 1:59 PM
    Blumpkinson
    Blumpkinson [OP] Fuelled by plutonium and wild animals
    OR
    03 4x4 5spd
    Neither of my front turn signals work and the indicator light is flashing fast, however both of the back turn signals work. I have replaced the fuses and i have also replace both front bulbs. Could it be that the turn signal relay has gone bad?
  2. Sep 2, 2009 at 3:56 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    What year Tacoma?
  3. Sep 2, 2009 at 3:58 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven
    '17 Inferno DCSB O/R
    STOCK 4 NOW
    if you've replacd the fuses and bulbs, it could be the relay. im not positive though
  4. Sep 2, 2009 at 5:03 PM
    Blumpkinson
    OR
    03 4x4 5spd
    it an 03, could i get the relay at autozone?
  5. Sep 2, 2009 at 6:28 PM
    Hootbro
    Hootbro Omnipotent
    Delaware
    2009 Tacoma Regualr Cab 4x4 2.7L
    Did you try looking? Anyway, I doubt the relay is your problem as it is still working for the rear. The fast flashing is because the load is not being sensed on the relay to cause it to slow down. I would double check the wiring before shotgunning a relay in.
  6. Sep 2, 2009 at 6:55 PM
    Blumpkinson
    OR
    03 4x4 5spd
    Thanks, the guy who owned the truck before me had fog lights in the front and when he took the lights he left the wiring, which is connected to nothing. Im assuming that has nothing to do with the signals though. Could the wire be exposed somewhere and shorting out?
  7. Sep 2, 2009 at 7:30 PM
    Hootbro
    Hootbro Omnipotent
    Delaware
    Doubt the fog light wiring is the issue directly but I would look at what was disturbed under the hood.
  8. Sep 2, 2009 at 7:34 PM
    Blumpkinson
    OR
    03 4x4 5spd
    Yeah he spliced some wires to run the lights not sure exactly what he did. Guess ill have to take a look at it tomorrow morning, hopefully thats the solution. Cause i really need to get it inspected.
  9. Sep 5, 2009 at 8:00 AM
    Blumpkinson
    OR
    03 4x4 5spd
    Alright i've got a stupid question that will must likley solve the problem. I replaced the relay and now the flasher indicator works normally however i still have no turn signal up front. My question is on the main headlight assembly the corner lights are the actual turn signals right? B/c when i went to pick up bulbs it said they were side markers and the actual turn signal bulb was much larger. My other question is it seems like that larger bulb would fit in the lower light (which i thought was a fog light), is that the actual turn signal? Cause im gonna be kicking myself if it is.
  10. Apr 23, 2016 at 11:20 AM
    Myfirsttacoma00
    Myfirsttacoma00 Member
    Blumpkinson that's what I thought at first too but I think the Corner light next to the headlights are just parking lights that aren't supposed to blink. You will have to modify it yourself or pay someone to do it. I'm still trying to modify mine myself or at a low cost if someone else does it
  11. Apr 23, 2016 at 11:39 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, 31" tires, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera, CB
    What happens when you turn on the hazard lights? That is supposed to cause the turn signal lights to flash.
