Turn signal side mirror
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BeefedTacos, Jan 30, 2021.
  1. Feb 3, 2021 at 4:12 AM
    #41
    BeefedTacos
    BeefedTacos [OP] Well-Known Member
    Brian
    North Carolina
    2015 tacoma dcsb SR5 4x4
    None so far
    I know I can check continuity with a meter. For example, connecting the meter on both ends of a wire and seeing if you hear a beep. That’s as far as my knowledge goes for using the meter hah. How did you go about checking it for turn signal wire?
  2. Feb 3, 2021 at 1:16 PM
    #42
    Ryan2103a
    Ryan2103a Well-Known Member
    SoCal
    2011 Sequoia 4x4 2022 SR 4x4
    I disconnected the tail light and ran a long wire connected to the turn signal plug from the tail light and checked the continuity from the long wire and the wire that I pointed out. I don't know if that made sense lol
  3. Feb 4, 2021 at 4:26 PM
    #43
    BeefedTacos
    Brian
    North Carolina
    None so far
    Well they say when you assume, you only make an ass of yourself. In my case, I found out my sr5 was already prewired for the lights :facepalm:lol. Went through a whole process of soldering the old 090 connections back into the plastic. A simple plug and play lead into hours of salvage.
    Lesson learned and thanks for everyone’s help!
    TnShooter likes this.
  4. Feb 4, 2021 at 4:42 PM
    #44
    caribe makaira
    Caribbean, Puerto Rico
    :rimshot:
