Turn signal Trouble
Discussion in 'Lighting' started by collector69, Mar 20, 2013.
  1. Mar 20, 2013 at 6:38 PM
    collector69
    collector69 [OP] Member
    Curt
    Lexington, MA
    2001 Tacoma
    Hello my left turn signal on my 2001 Toyota Tacoma works fine but my right works as follows sometimes it does not light on the panel and makes a very fast clicking sound, sometimes it lights on the panel at the normal speed. I haven't looked outside at the turn signals when I put the right signal on and I'm hoping it's a faulty bulb.
  2. Mar 20, 2013 at 6:49 PM
    Tacoma Mike
    Southern Maine
    Like you said look at your bulbs when it acts up.
  3. Mar 21, 2013 at 5:02 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    you have a bulb out...
  4. Mar 21, 2013 at 5:19 AM
    DR007
    DR007 Well-Known Member
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    MagnaFlow exhaust, K&N cold air intake, MB TKO wheels with 265/75/r16 Hankook Dynapro ATM, Blue Center shift LED color change, Map Lights with Dome, LED Map and Dome lights, Cluster Light Change, DTRL, Parking Light as Blinker, Blue A/C Control lights, Blue Clock, Bed Lights, Debadged tailgate, painted all exterior plastic trim, 6LZ Lightbars in grille, OTRATTW switches, Fog Light in Reverse light Mod, LED Blinkers all around, Projector Fog Lights, 15" blitzpro light bar, added hidden cig lighter port, custom plate front bumper, OME complete lift with 885 front coils, Ultraguage, CB radio 3' whips, 12v bed lighter port, Center Console Lights, AllProOffroad Sliders, 50" roof led light bar, 2 BlitzPro 6LZ Reverse Lights
    If its not the bulb it could be a short in the wire. Lets hope its just the bulb.
  5. Mar 21, 2013 at 8:47 AM
    collector69
    Curt
    Lexington, MA
    2001 Tacoma
    I looked at the bulbs today when I put my right turn signal on and they don't light when it dosen't light on the inside and makes a fast clicking sound but they do light when I pull the lever towards me and then push it up in other words I can force the turn signal on will this cause me to fail an inspection? I was hoping it was a bulb but that dosen't seem to be the case.
  6. Mar 21, 2013 at 2:09 PM
    Tacoma Mike
    Southern Maine
    yes you will fail.
    you can try getting a couple of bulbs anyway. Have seen wierd stuff with shorted bulbs. Or be real cheap and swap bulbs from the other side.
    Do you have an aftermarket trailer wiring setup ?
    are the bulbs lighting on that side only when you FORCE IT ???
    Need to eliminate easy things first.
