Turn Signal Wiring / Fixing Hyperflashing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OdiN1701, Jul 16, 2017.
  1. Jul 16, 2017 at 9:54 AM
    OdiN1701
    OdiN1701 [OP] Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    Since nobody apparently knew, putting this here for reference.
    The below photo shows the wiring for the driver side taillight. The white/black wire is ground and the larger yellow wire is the turn signal wire. On the passenger side, the turn signal wire is grey. These are the two wires you need to bridge with the resistor to fix hyperflashing.
    The next photos show where I mounted the resistors. They shouldn't come into contact with anything here. Basically I put them up as high as possible while still being able to get my drill in to mount them.
    I put spade connectors on the ends of each wire to the resistor and then added another length of wire to them in order to be able to have enough slack to lay the taillight on the tailgate without straining anything.
    I used posi taps and electrical tape to keep things tidy.
      File size:
      92.9 KB
      522
      File size:
      59.5 KB
      449
      File size:
      138.4 KB
      468
    burr, ktbell444, El Latigo and 5 others like this.
  2. Aug 25, 2017 at 9:57 AM
    daohaus
    daohaus Well-Known Member
    Duan
    33.960892 -117.575824
    18 TRD Off Road Premium 4runner
    Rotiform SIX OR Toyo Open Country RT
    thanks for this
    Catstravaganza likes this.
  3. Sep 19, 2017 at 2:25 PM
    BigSkyTRD
    BigSkyTRD Active Member
    Bozeman, MT
    '17 TRDOR DCSB QS
    Yes, This :thumbsup:
    ...and, if you are doing all 4 corners, you need 4 resistors.
  4. Sep 19, 2017 at 2:26 PM
    OdiN1701
    Colorado
    You mean the front too? Yes, in that case you would, but this is only the wiring for the rear.
  5. Sep 19, 2017 at 2:30 PM
    BigSkyTRD
    Bozeman, MT
    '17 TRDOR DCSB QS
    Yes, you need 4 if adding LEDs to the front also. Your wiring for the rear is spot on!
  6. Sep 19, 2017 at 2:32 PM
    OdiN1701
    Colorado
    I haven't bothered with the front yet. Not sure if I will.
  7. Sep 19, 2017 at 2:34 PM
    daohaus
    Duan
  8. Sep 19, 2017 at 2:37 PM
    OdiN1701
    Colorado
    Ahh I looked for those but could never find them.
    daohaus likes this.
  9. Sep 19, 2017 at 9:52 PM
    daohaus
    Duan
    BTW what ohm resistors did you get
    NM I zoomed in and saw
  10. Oct 6, 2017 at 12:09 PM
    Leo4x2
    Leo4x2 Well-Known Member
    Leo
    San Antonio, Tx
    2016 Toyota Tacoma SR5
    Maxtrac/Bilstein suspension 16x8 Pro Comp 69 315/75/16 Dick Cepek Morimoto Profile Prism RGB Halos & Demon Eyes
    What wires would you splice into for the front? They are also numbered 1,2 & 3. #3 is the ground (b&w) on both driver/passenger. I am assuming #1 is the blinker/turn wire and #2 is the parking wire?
  11. Oct 14, 2017 at 10:26 PM
    itsraymondang
    itsraymondang Spam King
    Houston, TX
    2017 White TRD Sport DCSB
    Shit.. I tapped the resistor into the white/black wire and green wire. But it still fixed the hyper flash lol
  12. Jan 31, 2018 at 4:42 PM
    commbubba19
    commbubba19 Well-Known Member
    '23 TRD PRO
    Thank you for this. Did my rear turn signals no problem.
    I didn’t have any screws that would hold the resistors to the inside panel so I used 3M tape.
    Props to the OP.
  13. Jan 31, 2018 at 4:43 PM
    OdiN1701
    Colorado
    I just used some random self tappers i had lying around.
  14. Jan 31, 2018 at 4:49 PM
    dj0mladen
    dj0mladen Well-Known Member
    Milan
    New Hampshire
    '17 TRD Sport Double Bed
    This is perfect. I just had UPS deliver the led bulbs. How about front anyone?
  15. Jan 31, 2018 at 5:00 PM
    OdiN1701
    Colorado
    I didn't have to do anything special in front. Just swapped bulbs. But I did add extra resistors in the back since I did the tail as turn mod too.
    If you need them in front I think there's just two wires since they are turn only. I didn't actually look though.
  16. Feb 1, 2018 at 7:58 AM
    commbubba19
    '23 TRD PRO
    Yeah, I was annoyed i couldn't find any self tapping screws small enough.
    The newer LED 7440/7443/7444 ambers do not seem to need resistors. From what I've found, 7440 are intended for on/off only such as blinkers and taillights (not running lights).
    If the light has to function as both a running light and blinker/brake, they use 7443/7444 which have they hyper flashing issue.
    I used these for the front turn signals:
    https://www.amazon.com/gp/product/B074YVZD4X/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
    These for the rear taillights:
    https://www.amazon.com/gp/product/B07559QVX5/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
    and these resistors:
    https://www.amazon.com/gp/product/B00L4V9ECY/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
  17. Feb 1, 2018 at 8:10 AM
    El Latigo
    El Latigo Well-Known Member
    Anaheim CA
    2017 MGM TRD OR Double Cab Short Bed
    Exactly what i was looking for to install my new LED blinker bulbs.. Thanks for the information!!.. :thumbsup:
  18. Mar 9, 2018 at 7:43 AM
    commbubba19
    '23 TRD PRO
    My passenger side randomly hyper flashes even with a 6Ohm resistor. Thought it was a bad resistor or crimped wire but no luck. It will flash normal even with lights on and as I make a turn it will begin to hyper flash. So weird. I want to do more like Tail light as Turn but getting this to work consistently is annoying.
  19. Mar 9, 2018 at 7:49 AM
    OdiN1701
    Colorado
    I had to add some 3Ohm in series to get mine to work with tail as turn.
    Here's the post:
    https://www.tacomaworld.com/threads...rake-and-signals.471450/page-11#post-16612198
  20. Mar 9, 2018 at 7:50 AM
    commbubba19
    '23 TRD PRO
