Turn Signal Wont Turn OFF!!
Discussion in 'Lighting' started by priebedog, Mar 20, 2011.
  1. Mar 20, 2011 at 12:43 PM
    priebedog
    priebedog [OP] New Member
    London, ON
    Race Track Blue
    Hey Guys, My left turn signal wont turn off, it will still flash when signaling and the dash lights will flash with it when my lights are turned off. Fuses are good and I have replaced the bulbs numerous times.
    My X-Runner has a DRL module installed since this truck was imported from the states, also have a towing package.
    Any thoughts????
  2. Mar 20, 2011 at 12:44 PM
    ckeeton
    ckeeton Bazinga
    Duluth, GA
    2011 DC Trd Sport Gray
    trd sport with avid off road light bar, avid rock sliders. OEM roof rack, 12' LED light bar, and Sock monkey decals.
    do not know to much on the electrical side but have you tried disconnecting the battery for a little?
  3. Mar 20, 2011 at 1:07 PM
    priebedog
    London, ON
    Race Track Blue
    Thanks for the quick Reply
    I disconnected the Battery for 5 mins cleaned the connectors and leads, but still same issue.
    Turn signal stays on.
    Any other ideas??
  4. Mar 20, 2011 at 1:19 PM
    ckeeton
    ckeeton Bazinga
    Duluth, GA
    oh then i really do not know what to do haha. like stated before i do not know to much on the electrical side of our trucks. hopefully someone else will chime in here to help.
    good luck man
  5. Dec 29, 2013 at 7:47 PM
    averagetaco
    averagetaco New Member
    North East USA
    09 stock
    I just started troubleshooting this exact same issue! I have a 2009 stock access cab and this is really annoying.
    The good news: It's a short.
    The bad news: it's probably a whole harness if I can't find a bad plug.
    I'll let you know what I end up finding tomorrow.
  6. Jan 3, 2014 at 8:48 PM
    averagetaco
    North East USA
    09 stock
    Problem was fixed at the mechanics today because I had to go out of town the next day for work. Here's what ended up happening.
    One of the bulbs (they didn't diagnose which) was receiving a feedback signal (faulty ground or something of the like) that essentially applied power to the bulb again. The way the wiring works is all bulbs need to be on the same status being on the same circuit. So when either of the bulbs got a false hot, they other two illuminated to compensate and "correct" the error.
    Remedy was as follows: Replace both turn signal bulbs, inspect and ohm out wiring, clean harness, add a few tape pieces to keep it neat, put it back together and reset computer, battery, cycle power. Problem solved for less than $75
    Hope that helps.
