Turn Signal works, doesn't, fast blink etc
Discussion in 'Technical Chat' started by RockTock, Nov 20, 2013.
  1. Nov 20, 2013 at 6:09 PM
    RockTock
    RockTock [OP] Well-Known Member
    Colorado
    1999 2.4 4 Banger SR5
    Not sure its a relay issue. Its funky on the LEFT side only. Sometimes it blinks fast, (no light, but you can hear it 2x as fast) sometimes it is normal. Not sure replacing the turn signal relay would do it.
    *Also, in case I can't find the repair manual, where is the TS relay located? Thanks!!
  2. Nov 21, 2013 at 7:12 AM
    fyremanpat
    fyremanpat Well-Known Member
    Pat
    757
    2013 DC LB TRD Sport w/Entune
    OME 886x and 5100's all the way around. Toytec AAL. Phillips x-treme vision headlights. 886 reverse lights. Borla exhaust. 20% tint. Hi 6 mod. 285/65/18 Nitto TG on 18" Moto Metal 955's. Airaid intake. Scanguage2.JBA LT's.GC Grill..more to come.
    was it all of a sudden or did you recently replace bulbs?...or is a bulb burnt out somewhere?
  3. Nov 21, 2013 at 7:15 AM
    Aw9d
    Aw9d That one guy
    Is the 1999 a thermal blinker relay? Might just be going out and needs to be replaced. My motorcycle has a thermal and it won't blink at all until it warms up, then it blinks fast, then it blinks normal after it fully warms up.
  4. Nov 21, 2013 at 8:13 AM
    RockTock
    Colorado
    There are no bulbs burned out or anything, no replacements. Its only one side and it seems to be connected to the turn signal lever.
    When it blinks fast, if I turn off then on slowly it may go to normal.
  5. Nov 22, 2013 at 6:00 PM
    Pakrat
    Pakrat Well-Known Member
    Brian
    Washington,State Columbia gorge
    02 tacoma xtracab 4x4 stock
    Front dome light added,light reminder added,door chime mod, added 2nd gen 4runner headrests,grey wire mod, 2lo mod, more later.
    I'm pretty sure your turn signal flasher is on top of your fuse panel in the cab.
  6. Nov 22, 2013 at 6:44 PM
    RockTock
    Colorado
    Ok, thanks, but I wonder if its more an issue with the turn lever as it sometimes works. The blinker light on the inside does not work when it blinks fast. You just hear clickclickclick...
  7. Nov 29, 2013 at 10:47 AM
    Tenalquot
    Tenalquot Member
    This is the exact issue I'm having with my '99.
    Bulbs and holders check out. R turn signal works fine. L turn is the problem- sometimes works fine, sometimes fast-blinking and no lights activate.
    Since I can temporarily "fix" the problem by moving the lever/switch arm, I strongly suspect it's the switch and not the relay or bulbs. Anyone replace a switch assembly before?
  8. Nov 29, 2013 at 6:39 PM
    RockTock
    Colorado
    I'm calling Toyota Monday, maybe they know.
  9. Dec 10, 2013 at 5:40 PM
    Tenalquot
    Tenalquot Member
    Success! Ordered a replacement turn signal/headlight lever switch. $47 and easy to install. Turn signals work great now- no "fast blink."
    I guess 14 years and 260k miles is their limit.
  10. Dec 15, 2016 at 10:28 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Happened to me today in my 2001 . First time ever.
    Right turn signal on, super fast blink. Turn it off, didn't repeat it at all all day. Normal blink since that once.
    All lights are functional
    Was it a fluke or issues to come ?
  11. Mar 11, 2023 at 1:44 PM
    Wolfjesus
    Wolfjesus Member
    Colorado
    2001 Tacoma TRD
    OME 881's with nitro charger shocks and full Dakar leaf pack
    I am having this issue now in my 2001. Have been getting the fast blinking on indicator light off and on for about a month. I've just let it go and had not checked during that time if the lights were functional. On a recent trip, the fast blinking of the right side TS indicator on the dash went from intermittent to constant. I assumed it was a bulb. Front right TS bulb was burnt out, but replacement did not fix the issue, and left front TS light not operating (Left TS indicator is normal). I suspect it is an issue with the signal/headlight lever switch. For some time now, the dashboard lights blink off for a split second when I flick the lever to actuate the TS lights. What is a good way to test this, other than just ordering replacement parts?
  12. Mar 12, 2023 at 10:31 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Perhaps clean the sockets and the bulb bases .
    Check with a Meter at the light if no voltage there check at the plug where the combination switch plugs in to the harness.
    Your dash lights should not be connected to the turn signal the only common point is the ground points
    Unless the System voltage is so low it draws everything down . Battery and Charging system working correct?
