Turn Signal
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Azelk2, Nov 6, 2020.
  1. Nov 6, 2020 at 5:46 AM
    Azelk2
    Azelk2 [OP] New Member
    2017 Tacoma TRD
    My turn signal works when the lights are off, but when the lights are on the rear acts like the bulb is burned out.
    Any thoughts would be much appreciated.
  2. Nov 6, 2020 at 5:58 AM
    Azelk2
    2017 Tacoma TRD
    I havent, just bought the truck though
  3. Nov 6, 2020 at 6:13 AM
    Tacospike
    Two Trucks
    Take it back and let them fix it.
    Skydvrr and Boghog1 like this.
  4. Nov 6, 2020 at 6:14 AM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    Could be bad wiring, defective bulb, or the fuse needs to be replaced.
    MyDogsTruck and Tacospike like this.
  5. Nov 6, 2020 at 6:19 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    What do you mean? As in the tail light doesn't glow, or as in nothing happens at all?
    Tacospike likes this.
  6. Nov 6, 2020 at 6:23 AM
    Azelk2
    2017 Tacoma TRD
    So, when your turn signal bulb burns out, the flasher for which ever side is out flashes very quickly, you go back look at the tail light and the bulb is not flashing. This is the situation when the headlights are in the on position. When the lights are on for night time driving the turn signal indicates the bulb is out. However, when the headlights are not on daytime driving the turn signal works properly...make sense?
  7. Nov 6, 2020 at 7:20 AM
    MyDogsTruck
    MyDogsTruck Well-Known Member
    W. Canada
    2020 TRD Sport
    Just to confirm, it's your rear signal lights that do not work when the headlight switch is in the on position? If so, it sounds like there is a short between the taillight circuit and the signal circuit. If that's the case, start by replacing the affected light with a known good bulb. If it persists, start inspecting wiring and connectors for signs of damage/poor connections.
    RedWings44 likes this.
  8. Nov 6, 2020 at 7:21 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    This
    I understand OP just bought this truck, BUT profile is listed as a 2017, so not new.
    Does this truck have any aftermarket doodads, or is it strictly 100% stock?
    Look first, where the human was last
    Tullie D and Boghog1[QUOTED] like this.
  9. Nov 6, 2020 at 7:57 AM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Grounds, grounds, grounds
  10. Nov 6, 2020 at 1:33 PM
    RedWings44
    Michigan
    Just making sure it isn't as simple as one filament being out and just needing a new bulb is all. Have you confirmed that the previous owners didn't install LEDs? I feel like this is less likely, but could be a cause nonetheless if they didn't get the proper bulbs or use the proper resistor if the bulbs required it.
    Chew likes this.
