Turn signals and hazards not functioning
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TRD_Kilo, Mar 12, 2025.
  1. Mar 12, 2025 at 11:01 AM
    TRD_Kilo
    TRD_Kilo [OP] New Member
    Brandon
    2018 Tacoma TRD Sport
    Hello everyone, first time poster here. Currently ran into a problem with my taco. I’ve been having intermittent problems with my turn signals and hazards. The problem would be they would all cut out, as if a bulb was burnt out. Typical hyper flashing on the cluster, my hazards would not work either but would show on the cluster as if they were functioning. I’ve had this problem for a year and would happen every couple months. I’ve learned that letting the truck sit overnight would resolve the issue the next day. A couple of days ago it happened as per usual but now they will not revert after letting the truck sit and battery disconnected. I’ve checked wiring and fuses all checked out to be fine, I’ve even replaced the battery the other day and no fix. Any words of advice? I’m starting to think my combination meter might be damaged for the flasher portion pertaining to my turn signals and hazards. I do have aftermarket headlights, the low beams and high beams are halogen but the drl is led.
  2. Mar 12, 2025 at 1:02 PM
    BraveRifles3
    BraveRifles3 Active Member
    Sorry to hear! Flaky relay, maybe???
  3. Mar 12, 2025 at 5:35 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I’d start with the aftermarket lights for sure.
    GL
    BillF1564 likes this.
  4. Mar 13, 2025 at 9:48 AM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Much agreed.
    Our trucks do not have a flasher or relay for the signals. All is contained within the Combo Meter.
    I believe the OP is on the right path with the Combo Meter suspicions.
    BraveRifles3[QUOTED] likes this.
  5. Mar 14, 2025 at 7:00 AM
    TRD_Kilo
    Brandon
    Yeah i haven't had much time to thoroughly check with a meter but my fuses are all good. Disconnected both lights and still all my signals for my mirrors and rear tail lights are still not functioning. Going to try to get a combo meter from the scrap yard this weekend. Anyone know what resistance/voltage readings i should be getting for my headlights and their respective connectors?
  6. Mar 14, 2025 at 7:56 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Do you have your original headlights? I would suspect the aftermarket housings are the culprit. If you don't, try putting a 50Ohm load resistor across the turn signal leads of the headlight harness and see if the corresponding tail light flashes. Are the tail lights stock?
    Chew likes this.
  7. Mar 14, 2025 at 9:08 AM
    TRD_Kilo
    Brandon
    I got into an accident had both my headlights broken and got aftermarket ones, the tail lights are oem though
