Turn signals come on when using brakes??
Discussion in 'Technical Chat' started by littledvl, Aug 4, 2011.
  1. Aug 4, 2011 at 6:16 PM
    littledvl
    littledvl [OP] ride BMX!
    Eric
    Saint Leonard MD
    08 taco dc 4x4 / 15 tundra dc 4x4
    Too many to list
    Ok, this started last night while driving to the store, I noticed everytime I hit the brake the left turn signal light in the dash came on, I assumed I had a left brake light out..
    After getting home I had my gf hit the brakes, there was no brake light out or any light for that matter. I did notice the left front and rear turn signal lights came on when hitting the brake.
    I been told a short in the 7pin would cause it but I unpluged it and it still does it. Both tail lights are stock, only had the passenger one out to replace a bulb.
    How would I go about finding out whats causing it?
  2. Aug 5, 2011 at 7:43 PM
    littledvl
    Eric
    Saint Leonard MD
    Too many to list
    Bump
    Pulled the tail light out, checked everything, still does it.
    Dealer cant look at it until the 16th..
  3. Aug 5, 2011 at 7:50 PM
    Hardwater
    Hardwater Well-Known Member
    Great Falls, MT
    2011 MGM TRD AC
    1.5" Add-A-Leaf, Toytec Coilover kit @ 2", LR UCA's, Bilstein 5100's all the way around, ProComp 7032's, 265/75 16 Duratracs, bed mat, Weather Techs Digital Fit Floor Mats, Wet Okole Seat Covers, Satoshi
    Is your turn signal switch going 100% back to center? Other than that, I would check all your grounds, a bad ground can cause some strange things.
    I assume your seeing the signal come on in the dash as well.. I am not 100% familiar with the Tacoma's wiring, but usually there is a plug near the rear axle that branches out to your tail lights and trailer harness. disconnect here and see if it still does it.
  4. Aug 5, 2011 at 7:52 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Definetly sounds like a shorted wire. I'll look up a wiring diagram and see what I can find.....
  5. Aug 5, 2011 at 7:58 PM
    littledvl
    Eric
    Saint Leonard MD
    Too many to list
    Turn signal switch is centered, and I tried unplugging the trailer harness with no luck. Ill check grounds tomorrow
    Thanks
  6. Aug 5, 2011 at 7:58 PM
    NelsonTacoma
    Tucson, AZ
    Do you have trailer wiring? I've heard on the 1st gens that trailer wiring can cause this same issue. Might want to start there. There is a 30amp fuse and a relay for the towing circuit in the engine compartment fuse block, pull those out and see if it does it.
    Edit: Just re-read first post and you already tried this......
  7. Aug 5, 2011 at 8:10 PM
    NelsonTacoma
    Tucson, AZ
    Here's the wiring diagram.
    Maybe try pulling the relay or fuse for the tail lamps and see if it goes away. If it does then you know it's in the rear. Or check the ground on the frame rail.
  8. Aug 5, 2011 at 8:35 PM
    littledvl
    Eric
    Saint Leonard MD
    Too many to list
    +1 ^^
    Awesome, thanks for finding the diagram.
    ill look over it tonite and start tracking things down tomorrow if it aint raining.
  9. Aug 5, 2011 at 8:37 PM
    NelsonTacoma
    Tucson, AZ
    Anytime. Let me know if you figure it out. :):)
  10. Aug 5, 2011 at 8:51 PM
    gtrotter
    gtrotter Well-Known Member
    Interlake, Indiana
    2009 Regular cab 4x4, ARB's, 4.88's, bumpers, 2017 DCSB SR5 stock,2008 Reg. Cab 4x4
    locker,mud tires, lifted, toolbox
    Electrical gremlins! I wish you the best of luck.
    My first car, 93 Chevy Lumina, had one. Every time I hit the left turn signal AND turned left, the car would die? Haha, just stopped using the left turn signal.
  11. Aug 7, 2011 at 9:00 PM
    littledvl
    Eric
    Saint Leonard MD
    Too many to list
    Well, I checked everything I could saturday, still did it. Today on the otherhand it never did it once so im not sure what to think, I guess ill just wait and see if it comes back. Seems like its something loose somewhere..
  12. Aug 7, 2011 at 9:12 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    this same thing happened to me, it was cause a tire was shorted
