turn signals coming on when braking
Discussion in '1st Gen. Tacomas (1995-2004)' started by Nick_Taco, Jul 17, 2011.
  1. Jul 17, 2011 at 12:29 PM
    Nick_Taco
    Nick_Taco [OP] Well-Known Member
    Nick
    Maryland
    2014 DCSB OR 4x4 Auto
    I've had this problem for a while now but it has gone away before....this time it wont. When I brake my turn signal lights on the dash come on solid (not blinking). If I'm braking and turn on a turn signal they will blink at an odd rate.
    I had wiring for 3rd brake light for my Leer cap but I cut the wiring out yesterday as I rarely use the cap anymore and now the light on the driver side of the dash has gone out but so has my driver side turn signal...:mad:
    I do have wiring for a trailer but I had this problem before I got that wiring.
    Checked all bulbs and fuses and can't seem to find anything wrong.
  2. Jul 18, 2011 at 10:30 AM
    Tylerm5000
    Tylerm5000 Well-Known Member
    Tyler
    Oregon
    1995.5 2.7l reg cab 4x4 5-speed red pearl
    Alcan stock height 4-leaf springs, greaseable main eye bolts, OME greaseable shackles, all energy suspension bushings, 2-row extra deep radiator, KYB gas-a-just shocks. ALL LED exterior and interior lighting including custom tail lights and blinkers.
    Do you have any LEDs? I had this same problem because I changed all of the dash lights (all of them) as well as the rest of the truck to LEDs, but the dash blinkers had weak resistors in them. I changed the bulbs and it fixed the problem.
    There is probably either a disconnected ground or a short somewhere. I would just pull all lights out and check them and their wiring.
    Hope that helps. haha. It can get annoying.
  3. Jul 18, 2011 at 10:34 AM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Selkirk, NY
    4x4 reg cab, 5 speed
    Better tires Hurcules Terra Track, trimmed front mud flaps, (access limited tonneau-took off) softopper, ats running boards, Piaa fogs, window vents, Wireless thermometer, extra bed rings, valley hitch
    You just did the "confuse the driver behind you" mod.
    Could a light bulb be dead? My old 92 toyota passeo had funig things go on when a brake light or center brake light was out or loose.
  4. Jul 19, 2011 at 9:17 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I had the same thing happen but it was the result of faulty trailer brake wiring. I'd guess it's in that cap wiring shorting somewhere
  5. Jul 19, 2011 at 9:27 PM
    Nick_Taco
    Nick
    Maryland
    turns out there was a bad ground
    thanks for the help though guys :cool:
