Turn signals not cancelling
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Burlingtonmarine1845, May 22, 2018.
  1. May 22, 2018 at 12:43 PM
    Burlingtonmarine1845 [OP] New Member
    Larry
    2010 Tacoma. 4x4
    I had to replace the clock spring in my Toyota. After I got it all back together the light was out and everything was working. I started to back up out of the barn and as soon as I turn the steering wheel the airbag light came on.My horn still works and my radio control on the steering wheel works. But my air bag light is still on and I noticed the turn signals are not cancelling when I go around a corner. I don't think I snapped anything inside the steering wheel I will have to take it off next weekend to see. I really don't know what cancels the turn signal. It maybe that piece under the clock spring.Does anyone know?
  2. May 22, 2018 at 12:56 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I think there's a little stationary lever inside that's activated by a tooth on the clock spring. I looked at it once when I had the steering wheel apart. There might be a component like that lever missing. Hope you figure it out.
  3. Feb 16, 2020 at 9:38 AM
    quicksilver1
    quicksilver1 New Member
    Corpus Christi
    TRD Sport
    Did you figure this out? My left blinker does not cancel but my right one does. No airbag light either. Really annoying.
  4. Feb 16, 2020 at 10:54 AM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    For OP I would assume your clockspring is physically broken, not wiring but that the little tab is broken off.
    For other person who's blinker cancels only one way I would say to check your switch but your clockspring could be just damaged enough that it still turns off one side and not the other, if that's the case I would assume in the near future both blinkers will no longer turn off.
  5. Feb 20, 2020 at 4:16 AM
    quicksilver1
    Corpus Christi
    TRD Sport
    Thanks for the reply. I figured I was going to have to take it apart twice. Once to diagnose and the other for replacement.
  6. Feb 22, 2020 at 6:53 PM
    joeyv141
    New Jersey
    Welcome to the life of a dealer tech.
    CTSpruceMica, TnShooter and b_r_o like this.
  7. Nov 22, 2022 at 7:18 PM
    kgwms1
    kgwms1 New Member
    2011 Tacoma Access Cab
    Just replaced my clockspring and all the electronics worked, but the turn signal wouldn't always cancel. Got back into the clockspring and find that I didn't press it in well enough to engage the three clips that hold it in place. Engaged all three clips properly and everything works correctly including turn signal cancellation.
    Taco 422 and TnShooter like this.
