Turn Signals Not Working 2002 Taco
Discussion in 'Technical Chat' started by cowboynico, Apr 22, 2013.
  1. Apr 22, 2013 at 6:41 PM
    cowboynico
    cowboynico [OP] Member
    Nico
    Gunnison, CO
    09 TRD Off-Road
    I am trying to help my buddy with his 02 TRD and apparently his turn signals stopped working today. The hazards work but really intermittently and only when the button is held down completely. Sounds to me like this is going to be rather involved wire-chasing nightmare but I just thought that is anyone has experienced this before that it would be beneficial to get some feedback. BTW all fuses are good and bulbs are copacetic. Thanks.
  2. Apr 23, 2013 at 9:55 AM
    BamaToy1997
    Bill
    Navarre, FL
    Actually, it probably won't be that difficult. The turn signal signal goes from the turn switch to the hazard switch, and from there to the lights. From the way you are describing the failures, I would think the hazard switch is bad.
  3. Apr 24, 2013 at 12:27 PM
    cowboynico
    Nico
    Gunnison, CO
    09 TRD Off-Road
    Thank You! I relayed the information and I think he has got it now. Super helpful and time saving. I think he is going to join TW now. Haha
  4. Apr 30, 2014 at 4:31 PM
    Jkohler
    Jkohler HUH?
    Justin
    UT
    02 4DR Taco TDR Supercharged SR5 6in lift
    12" Icon 2.5 coilovers, 6" Drop Bracket, Tuff Country 5" lift knuckles, Icon 4''-8'' Extended Coilovers, Light Racing upper control arms, 7" Alcan leafs, 13" icon 2.0 smooth bodies in the rear. 2.5" exhaust with Magnaflow cats and Thrush muffler. 295x75x16 AT's (34.4") Superchargers Other shit like rear breather mod relocate, gray wire mod, intake elbow removed, led's, toolbox, etc
    What if the hazards are still working?
  5. May 10, 2014 at 11:06 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    My bumper turn signal lamps work as expected, but my turn signal lamps next to the headlights do not work (parking lamps or flashing). I held the bulbs up to a light and verified that they are good. I traced down all of the fuses as well and they are fine. I'm not sure how to diagnose further because my digital multi-meter is too slow to read the high voltage when the blinker is activated.
    I'll let you know more when I figure it out.
    For your problem it sounds like a loose connection or frayed wire. Have there been aftermarket wiring added on for accessories that just snap onto current wiring? If this is the case, one of those may be drawing too much current and causing the relay to freak out.
  6. May 13, 2014 at 11:42 AM
    JasonLee
    15 TRD OffRoad
    Turns out my bulbs had a bad connection in the socket because after I took them out and plugged them back in a few times they worked.
