turn signals not working, airbag light on, and speedo not working.....:(
Discussion in 'Lighting' started by Jeremiah Stewart, Oct 16, 2010.
  1. Oct 16, 2010 at 9:23 PM
    Jeremiah Stewart
    Jeremiah Stewart [OP] New Member
    Jeremiah
    Colorado Springs, CO
    06 4X4 AC Impluse Red
    TRD Intake, Momo Pedals, Flowmaster Duel Exhaust
    :confused::confused::confused::confused: So I got in my 06 access cab today and found out that the turn signals aren't working. along with that problem, neither is my speedo and the airbag light came one...
    Questions
    1. Are there two flashers, as in one for the hazards and one for the signals or just a single flasher?
    2. Is a a correlation between the airbag light being on and the speedo not working? Also the nice little beep you get when you put it in reverse(manual trans) is not working either.
    If anyone has any ideas, they would be greatly appropriated.
  2. Oct 16, 2010 at 9:29 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Sounds like you have multiple seperate problems. 1. First step would be to get your truck scanned to see what codes come up. 2. There should be 2 flashers 1 for turn signals and 1 for hazards. 3. Speedo not working is probably the instrument cluster.
    It's possible the instrument cluster is causing the whole problem, but getting the system scanned for codes will get you a better idea of what is going on.
  3. Oct 16, 2010 at 9:54 PM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    check the fuses buddy and get it scanned.
    FYI, something similar happened to me awhile back and it turned out my battery had a bad cell and it fried my fuses that ran my instrument cluster. The funky thing is my battery still showed the correct voltage.
  4. Jun 16, 2011 at 1:38 AM
    cjtacoma
    cjtacoma New Member
    NY
    05 Tacoma DC SR5 Sport
    After re-wiring a trailer (obviously not that well) and then mvoing it around into a tight space and parking it , I find that my Tacoma's signals/speedo/odometer are not working. Firs thing I noticed was the red airbag light on the dash - followed by signals and speedo not working.
    After the next start the check engine light also came on.
    All fuses seem oOK wondering if it is a relay or somethng...
  5. Jun 16, 2011 at 4:27 AM
    cjtacoma
    cjtacoma New Member
    NY
    ...I am!??
    Sorry all I totally forgot about the fuses under the dash behind the change bin. It was one of those fuses that was out - the IG1 fuse.
    Anyway all is back to normal EXCEPT that the check engine light is still on - so I will have to reset later.
    Thanks again and sorry for completing the image of newbies being dumb as F&*#.
    CJ
  6. Mar 20, 2014 at 4:39 PM
    PNWB
    PNWB New Member
    Pacific North West
    Tacoma V6 six speed
    Thanks for posting this. I had this happen as well after wiring for a trailer. Same exact fuse blew out.
    Maybe it is coincidence about the trailer part? We drove the trailer for quite a while before the fuse went out.
    Time will tell.
  7. May 6, 2014 at 8:22 AM
    Manwithoutaplan
    ID
    So i had this issue yesterday and bought a OBD II Scanner got P0500 Error code.
    Poped some fuse that involved (IGI1 10amp Fuse).
    Fuse # 32
    -Which connects AC
    -Speedo
    -Air bag light
    - Turn signals
    Along with Tail light fuse which connects (#27 10 amp fuse)
    - Ac control units
    - fog light switch
  8. Jul 1, 2014 at 11:57 AM
    btuner
    btuner <<<<>>>>
    Brandon
    Hendersonville NC
    09 PreRunner SR5
    Stage III TRD Badge
    Came out from work to find no ac control, no blinkers, no cruise control and freaked out. First thing i did was check here and sure enough this thread saved me!
    IG1 fuse it was!
    thanks guys
