Turn Signals Not Working AlphaRex Pro Series Headlights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by white2red, Mar 7, 2024.
  1. Mar 7, 2024 at 1:59 PM
    white2red
    white2red [OP] Active Member
    OK
    2008 White TRD Sport DCSB, 2012 Red SR5 4x4 DCLB
    Everything but the engine
    2 months ago I bought a 2012 DCLB that already had AlphaRex Pro Series Headlights, which the dealer told me the previous owner had put on the truck. I’ve looked at the wiring and it all looks correct, but for some reason my turn signals do not work on these headlights. It’s not the common flashing issue I’ve seen posts about online, they just simply don’t work. I am at a loss for what to do. I’ve emailed their support and called once with no answer either time.
  2. Mar 8, 2024 at 3:00 AM
    2013XSPX
    2013XSPX Well-Known Member
    GA/FL Border
    2013 XSP-X
    Pelfreybilt front/rear, RCI underneath, Morimoto Headlights, Prinsu racks, SCS Brushed Copper Ray 10's, EO Sliders, Baja Designs and Rigid lights, Inca 4x4 Camper
    Are the turn signals part of the AlphaRex or are they just stock bulbs?
    Are your rear turn signals working?
  3. Mar 8, 2024 at 9:43 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    2013XSPX likes this.
  4. Mar 9, 2024 at 8:58 PM
    Silvermoose06
    Silvermoose06 Member
    Declan
    2008 Tacoma TRD Sport Black
    Bilistein 5100s Alpharex Pro Series Headlights Motometal 17" -10 Rims W/ Falken Wildpeak at3w Vivid Lumen FNG3 Fog Lights (SAE) Weather tech floormats LED Taillight/reverse bulbs
    If an LED bulb has been put in it can cause issues. And turn signals won't work or I think you might get hyper flash but I could be wrong...
  5. Mar 9, 2024 at 9:04 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    that brand is known to fail outright
  6. Mar 9, 2024 at 9:18 PM
    Silvermoose06
    Declan
    I don't necessarily agree. The brand has had issues but there are no good options for headlights. Ive had a set of pros on my 08 no durability issues and they are far better and brighter than the stock ones that also have issues with melting the drl. Issues come when guys buy the pros and put a cheap LED in.
    Revelations likes this.
  7. Mar 24, 2024 at 5:48 PM
    white2red
    OK
    I need to make a correction - I actually have the Luxx series and did not realize.
    Since my last post, I have taken my truck to an accessories shop where they told me it appears everything is connected properly, and essentially they had no idea. Just by looking at the wiring, I can tell that the previous owner had some issues with it too, as it looks like they got “creative” with trying to fix it. Even with their “creativity,” the wiring still appears to be connected properly. My parking lights and signals still do not work.
    Does anyone have any ideas?
    Thanks!
  8. Mar 24, 2024 at 5:50 PM
    white2red
    OK
    I’ll link a picture below that will show the DRL and the headlight beams working properly.
  9. Mar 24, 2024 at 5:52 PM
    white2red
    OK
    My rear turn signals work just fine. As far as I know (being the second owner of the truck and not getting any response from the previous owner), the bulbs are from the AlphaRex headlights.
    2013XSPX[QUOTED] likes this.
  10. Mar 24, 2024 at 6:54 PM
    dtaco10
    Dave
    I'm following this as I keep thinking about other lighting options.
  11. Mar 24, 2024 at 7:33 PM
    white2red
    OK
  12. Mar 25, 2024 at 10:50 AM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    It would help to see the actual wiring. Alpharex Luxx series requires you to wire in additional power to the lights. It has a small relay box that you need to wire into a +12v ign and a black wire for ground. The relay box connects between the DRL wires and the battery and +12v ign source. The red wire should have a fuse on it. I would also check that fuse to see if it's popped.
    Luxx relay box: Black > ground, Red > +12v (battery), Gray > +12v ign (either fuse tapped in the MFI relay in the engine fuse box, or wire is inside the cabin fuse box).
    https://alpharexusa.com/installation-guide-for-12-15-toyota-tacoma-headlights/
    Post pics of your wiring in detail. I have the same Luxx headlights and haven't had any problems with them.
    If the wiring is correct:
    1. Get a multimeter and test the wiring harness from the vehicle side to make sure you're getting voltage when the signal is activated.
    2. Once you establish the connection has power, connect an OEM bulb harness and regular bulb to see if the bulb will light up as normal.
    3. Post results.
  13. Mar 31, 2024 at 12:21 PM
    white2red
    OK
    I appreciate your help, but I have should have been more specific and updated this post already.
    I have already connected the multimeter to the signals and while they do light up when connected to power, they do not work once plugged into the truck. I have yet to try plugging in an OEM bulb (I bought the truck with these already installed so I do not have one) and I have pretty much narrowed it down to the truck. I am not sure what part of the truck is causing this, but again, no fuses are burnt, everything (now that I fixed it) is wired correctly, and both my signals work in the rear.
    Any other suggestions?
  14. Apr 1, 2024 at 5:01 AM
    Revelations
    2014 MGM DCSB
    How did you supply power to the headlights? Did you connect the gray wire to the battery? Where is the gray wire tapped into? If you think the truck is the problem, connect an oem bulb and see if it lights up. If it doesn't, then you should check the control box. You didn't specify if you have a TRD model, but some you may have a relay instead of the control box. If it does light up, then it's possible the alpharex relay is bad.
  15. Sep 1, 2024 at 5:16 PM
    bralex_m
    bralex_m New Member
    Alex
    08 SW TRD Offroad
    I installed the Luxx series as well for my 08 Super White TRD Offroad. I am having the same problem with turn signals not working for the headlights. In an installation video I saw the gentleman put the fuse into his engine bay fuse box, Alpha Rexx in THEIR installation have you run their harness with the fuse through your firewall and into the fuse box in the cab. I am going to try this tomorrow because I also have an issue with LED strip in the headlights not turning off when the truck is completely off and having me disconnect my battery whenever I turn in for the day. I also am missing an OEM connection from the truck where the old turn signal bulb was. I will update this thread if I can remember to on my next steps.
  16. Jan 2, 2025 at 7:45 AM
    white2red
    OK
    Any fix?
  17. Jan 2, 2025 at 11:14 AM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    I have ARex Nova lights on my ‘06. If the harness is the same, check the yellow wire where the connection is made to the stock lights and the ARex connector. Mine was loose, and pushed out the back of the plug. PITA to reseat it, but that was my problem.
  18. Jan 3, 2025 at 7:54 AM
    Marecco
    Marecco Well-Known Member
    Bucks County, PA
    2009 DCSB Tacoma
    Do the turns happen to work with the parking light or headlights to the ON position? I have a set that came on my truck and the turns do not work if the parking lights or headlights are not turned on. I believe the previous owner did not install them properly to get power without it coming from the light harness itself when they are turned on.
