Turn signals not working. Relay location?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco47, Jun 15, 2015.
  1. Jun 15, 2015 at 5:21 PM
    Taco47
    Taco47 [OP] Well-Known Member
    Norcal
    2016 2TR 5-Speed
    Just purchased this truck so I don't know the history. Turn signals don't work but hazard lights do. Trying to track down a separate relay for the signals aside from the hazard relay if that exist. Can someone tell me which relay I should test?
  2. Jun 15, 2015 at 5:31 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    How about horn and cruise? If those are bad, you got a bad clock spring.
  3. Jun 15, 2015 at 5:41 PM
    Taco47
    Norcal
    2016 2TR 5-Speed
    I doubt that's the issue because the turn signal lever is mounted after the clock spring and the spring only handles electronics mounted on the steering wheel like horn cruise stereo. Both horn and cruise do work though so thanks for the input.
  4. Sep 25, 2015 at 7:02 AM
    bonbizzy
    bonbizzy New Member
    Arturo
    2008 4x4 Tacoma
    I have an 08 and the same problem happen to me after I hooked up an electrical brake controller for my trailer what did you do to solve the problem cuz I can't seem to figure it out
  5. Sep 25, 2015 at 12:38 PM
    scottclarkinco
    scottclarkinco Well-Known Member
    Scott
    Denver, Colorado
    2014 MGM TRD Off Road
    A lot. Check out my build page.
    Second gen.....turn signal box is under the steering wheel behind the plastic dash. Kind of a bitch to get to and even worse to get out but it's in there.
  6. Sep 25, 2015 at 12:40 PM
    bonbizzy
    bonbizzy New Member
    Arturo
    2008 4x4 Tacoma
    Sweet so its were i hooked uo my trailer brake controller rite...... Thanks
  7. Sep 25, 2015 at 1:34 PM
    Taco47
    Norcal
    2016 2TR 5-Speed
    Bonbizzy, check your "IG1" fuse on the driverside foot well. Let me know what you find.
  8. Sep 25, 2015 at 2:38 PM
    bonbizzy
    bonbizzy New Member
    Arturo
    2008 4x4 Tacoma
    It was the IG1 fuse thanks alot
