turn signals not working
Discussion in 'Lighting' started by justin ensor, Jun 5, 2012.
  1. Jun 5, 2012 at 2:10 PM
    justin ensor
    justin ensor [OP] New Member
    83 tacoma
    I've got a 1983 Tacoma four wheel drive and just recently all the turn signals stopped working so far I've changed all the bulbs checked the fuses, could it be a wiring issue or a bad relay or maybe the turn signal switch?
  2. Jun 5, 2012 at 10:27 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Could be a lot of things. Do the hazards work? Not familiar with the older trucks, but there might be two flasher relays.....one for the signals, one for the hazards. If that's the case, might try swapping them.
