Turndown: Before or After Axle
Discussion in 'Performance and Tuning' started by RMAN808, Aug 3, 2012.
Turndown Tip Location???
Poll closed Sep 2, 2012.
  1. Before the axle
    23 vote(s)
    42.6%
  2. After the axle
    25 vote(s)
    46.3%
  3. Doesn't really matter!
    6 vote(s)
    11.1%
  1. Aug 4, 2012 at 6:53 AM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    The whistle tips go woooooooo woooooooooo.
    Is jus fo decoration, thas it and thas all.
  2. Aug 4, 2012 at 6:56 AM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    before
  3. Aug 4, 2012 at 6:57 AM
    RMAN808
    RMAN808 [OP] S)(AKALO)(AWAII
    Reid
    Pearl City, Hawaii
    '17 TRD OR 4X4 Quicksand
    Makes sense. I noticed that when I went to check under there. I currently only have two hangers (one right after the muffler outlet and then one near the tail pipe exit.
    I'm only looking at around $60ish plus tax. Hopefully it doesn't change when I bring it in on Monday.
  4. Aug 4, 2012 at 8:20 AM
    bigcuzauto
    bigcuzauto Active Member
    Louisiana
    2006 tacoma trd
    3 in coil spacer lift 285/75/16 buckshots dent in the rear
    may hang on trail if before axle I would go after or better yet out the back unless there is a big block in your taco
  5. Aug 4, 2012 at 8:57 AM
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
    Does cutting it after the axle cause any issues with the spare tire and heat from the exhaust being so close? I prefer the after the axle and plan on getting it done whe I put an exhaust on.
  6. Aug 4, 2012 at 10:56 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I haven't noticed any issues from exhaust heat at all. But the pipe is to the side of the tire, between it and the frame rail. Hard to tell from the pic but we cut the pipe so it extends below a majority of the tire yet not low enough to drag or be the lowest point.
    The most appealing part to me is the sound. No drone what so ever at highway speed, yet deep and throaty at idle and acceleration. Cutting off the end of the tailpipe definitely changes how it sounds.
    When I hear Ben's next week we can better compare the sound between before and after the hump as we have the same muffler. :cool:
  7. Aug 4, 2012 at 11:52 AM
    RMAN808
    Reid
    Pearl City, Hawaii
    I was kinda wondering the same thing except for heat on the axle if it were dumped obviously in before it.
  8. Aug 5, 2012 at 8:44 PM
    RMAN808
    Reid
    Pearl City, Hawaii
    BUMP :D
    Going in tomorrow. Just curious what your opinions are. Thanks!
  9. Aug 5, 2012 at 9:03 PM
    Shaggs
    Shaggs Well-Known Member
    NorCal
    2012 DoubleCab Long Bed 4x4 TRD Magnetic Gray
    Before the Axle, Magnaflows sound great
  10. Aug 5, 2012 at 9:09 PM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    Whistletips!!! LMAO:D "They go Whoot WHOOOOT" HAHA
    "They be up already makn they breakfast...They just a alarm clock"
  11. Aug 5, 2012 at 9:32 PM
    RMAN808
    Reid
    Pearl City, Hawaii
    Does anybody know about heat on the rear axle? I should make sure the exhaust isn't pointed "directly" at the axle, correct?
    I'm not too worried about the loudness from in the cab, just as long as it sounds good overall.
    That looks good man :thumbsup:
  12. Aug 6, 2012 at 5:50 AM
    RMAN808
    Reid
    Pearl City, Hawaii
    Final BUMPage :D
    Going in this morning to get'er done :wink:
  13. Aug 6, 2012 at 6:07 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Mine got a hollow sound after chopping it after the axle.....prob because the sound is now hitting the ground and not out the side! There's slightly more drone compared to side exit but the closer to the cab you chop the more drone/vibration you'll get! Prob won't notice since magnaflows are not as loud as flowmaster IMO!
  14. Aug 6, 2012 at 6:08 AM
    6spdtaco
    6spdtaco Well-Known Member
    VT
    Taco
    After.
  15. Aug 6, 2012 at 6:22 AM
    #35
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    ^^ Thats how mine is just with a muffler swap! A 4.5" grinder and 30sec of work and its done!
    Idle got quieter too but this is all with a super 44 so hard to say!
  16. Aug 6, 2012 at 6:55 AM
    #36
    RMAN808
    Reid
    Pearl City, Hawaii
    Yea that's what I'm thinking too when comparing it to the Flowmaster I have now. Yours looks good though man!
  17. Aug 6, 2012 at 7:45 PM
    #37
    RMAN808
    Reid
    Pearl City, Hawaii
    Swapped the mufflers today :D
    Went with the turn down tip before the axle. It sounds great. It's baby compared to the Flowmaster but still sounds good in the cab.
  18. Aug 6, 2012 at 9:36 PM
    #38
    Shaggs
    NorCal
    Thats how mine was, you are gonna love that setup
  19. Aug 7, 2012 at 1:10 AM
    #39
    Vigo
    Vigo WFO
    On a rock in the pacific
    '12 4 door
    stuff...
    Looks like its pointnig directly at the axle. Maybe its just the pic?
    Whered you take it, ESH?
  20. Aug 7, 2012 at 7:09 AM
    #40
    RMAN808
    Reid
    Pearl City, Hawaii
    It's just the picture :D
    Naw not ESH. I'm in Utah for school so I did it up here.
