Turning key and getting a one time click
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dtodd87, Apr 16, 2019.
  1. Apr 16, 2019 at 3:12 PM
    Dtodd87
    Dtodd87 [OP] Well-Known Member
    Dylan
    06 4.0L TRD OR
    Engine: 1GR-FE stock ARB Safari intake CSF Performace radiator Front Suspension: B8 6112 shocks B8 upper control arms Rear Suspension: B8 5160 shocks Deaver Expedition series 2 Leaf springs (stage 2)
    just hopped in my truck, when I went to start it and turn the key I heard a clunk and then one click
    Now every time I turn the key I get a simultaneous click, but it’s only once
  2. Apr 16, 2019 at 3:14 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Starter most likely.
    Make sure your immobilizer program is not flashing when this is happening.
  3. Apr 16, 2019 at 3:16 PM
    Dtodd87
    Dylan
    06 4.0L TRD OR
    No indicators are flashing on dash besides seat belt
  4. Apr 16, 2019 at 3:33 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Sounds like a DEAD battery. And to get one so dead it will only click sounds like the alternator died too. If I'm right you'll probably have to replace both the alternator and battery. I couldn't save the battery when my alternator died.
  5. Apr 16, 2019 at 3:36 PM
    Dtodd87
    Dylan
    06 4.0L TRD OR
    I just told tried jumping it to no avail
    Mostly the starter?
  6. Apr 16, 2019 at 3:36 PM
    Dtodd87
    Dylan
    06 4.0L TRD OR
    Most likely the starter*
  7. Apr 16, 2019 at 3:38 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Test the battery 1st. Good luck OP.
  8. Apr 16, 2019 at 3:39 PM
    Clearwater Bill
    Billy
    Largo Florida
    Sonetimes dead batteries are so dead they dont jump
    Pull it out and have it tested.
  9. Apr 16, 2019 at 3:44 PM
    Muddinfun
    Muddinfun Well-Known Member
    I vote for corroded battery terminals and $19.99 jumper cables.
  10. Apr 16, 2019 at 4:17 PM
    pinktaco808
    pinktaco808 Hot Steppa
    Extra jumper battery
  11. Apr 16, 2019 at 4:20 PM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    Or a bum ground connection.
    Bit me on the ass on my 1st gen... drove to the store to get coffee, fired right up at the house, got a click when I went to leave the store. Got one of my coworkers to come jump me, it was a real sonuvabish to get started, but it started & ran. At the time I had an Odyssey, my last of 3 in as many years, so since the other 2 had died I assumed this one was taking a dump, so I bought a battery at work.
    Put it in at home, still just clicks. I should've known at this point to step back, and start testing stuff, but I decided to double down, and get a starter. Yep, same thing. I'm thinking my positive cable is going bad at this point, so I clamp my battery tester to the starter stud & the battery negative, and it says it's great... I proceed to: facepalm: and move the negative clamp of the tester to the block, it says it's OK at rest, but hit the key to start & it drops below 9v and the tester shuts off.
    I loosen the bolt holding the ground cable to the block, clean up the area and retighten, bam, works fine. It had enough of a ground path through motor mounts and such to the frame to run, but try to run the starter... nope. :homer:
    This is my $300 lesson to not get all frustrated with dumb shit, and to take my time and diag stuff right.
  12. Apr 16, 2019 at 4:23 PM
    pinktaco808
    Check grounds any cut loose wire.
  13. Apr 16, 2019 at 7:54 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    pinktaco808 likes this.
