Turning off the 4L0 warning chime.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Collins, Mar 7, 2011.
  1. Mar 7, 2011 at 6:13 AM
    Collins
    Collins [OP] Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5spd, 4x4
    I searched, but found nothing.
    I want to turn off the warning chime when the truck doesn't go into 4lo.
    For some reason i have to futz around with the 4lo method,
    sometimes 4lo doesn't engage...i have to roll forward a bit
    and then retry...meanwhile the chime is stupid loud.
    Anybody figured a way to do this?...turn the chime off?...
    Thanks,
    Paul
  2. Mar 7, 2011 at 6:37 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    i wouldnt do it....because it tells you that you are doing it wrong
  3. Mar 7, 2011 at 6:55 AM
    crf69
    Ohio
    ummm yeah
    i wouldnt is what i meant....
  4. Mar 7, 2011 at 7:00 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    If you follow the directions and engage 4Lo appropriately, it won't chime. Novel concept I know. :D
  5. Mar 7, 2011 at 7:07 AM
    Collins
    North Carolina
    heh...
    i know how to do it, but engaging 4lo has been kind of hit or miss since
    i bought it new...a couple others on this forum said the problem
    gets better the more you use 4lo...not seeing that yet.
    I guess my problem is that i am not pushing the clutch in far enough?
    I don't mind the 4lo yellow flashing light in the dash...just the chime.
    I noticed it is a separate buzzer...just was wondering if it could be
    easily disabled without too much hassle.
    Paul
  6. Mar 7, 2011 at 7:36 AM
    macgyver
    Brad
    Canton, GA
    Probably this ^^^ That's usually the reason I get the chime sometimes. It happened to me the other day actually. Pushed the clutch in a little further and it engaged just fine.
  7. Mar 7, 2011 at 9:03 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
  8. Mar 7, 2011 at 1:24 PM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Essex county NY
    23 trd OR DCSB 4x4 silver
    a cross on my rearview Circle mirror Scotch guard seats
    4lo and key in ignition chimes I would not disable.
    Seat belt warning sound is diabled. My dog rides there and it drove me crazy after every stop.
