Turning on my ARB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MauiJR808, Nov 25, 2021.
  1. Nov 25, 2021 at 7:39 PM
    MauiJR808
    MauiJR808 [OP] Well-Known Member
    Jrey
    Hawaii
    2008 black tacoma 4x4
    Paint black with gold pearl with camper
    I Have a couple of stupid question but I just have to ask.
    1 Can I turn my ARB air rear locker on without using 4wheel drive??
    2 can I use it on 4HI??
  2. Nov 26, 2021 at 7:21 AM
    DJ77
    DJ77 Well-Known Member
    Donnie
    2009 Off Road
    New Boss stereo
    If you are on snow or dirt I don't see why not.
  3. Nov 26, 2021 at 7:26 AM
    Pigpen
    Dan
    Northwest Montana
    Yes you can.
    DJ77 likes this.
  4. Nov 27, 2021 at 7:19 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    yes and yes
  5. Nov 27, 2021 at 7:24 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Your arb air locker is completely independent of any systems on the truck so you can turn it on whenever you want. What I generally do is just turn it on at the beginning of a wheeling trip and just leave it on the entire time rather than try and remember to turn it on and off. I enjoy locking the rear in 2wd if I want to get a little rowdy on a fire road and want to "drift" around corners because it's easier to break traction and slide the ass around.
    6 gearT444E likes this.
