Turok....Louisiana Dinosaur Slayer Dad Rig Build
Discussion in '2nd Gen. Builds (2005-2015)' started by ragincajun35, Oct 24, 2015.
  1. Jan 12, 2016 at 8:32 AM
    #481
    ragincajun35
    ragincajun35 [OP] Well-Known Member
    Spencer
    Louisiana
    2015 DCSB MG TRD Offroad
    See Builds....
    DUDE!!!! i havnt been on your build thread in a while @zscott!! Shit is getting serious over there!!! IM going to have to go catch up on the work you have been doing.
  2. Jan 12, 2016 at 8:32 AM
    #482
    adrenalnjunky
    adrenalnjunky Well-Known Member
    West Monroe, Louisiana
    07 PreRunner SR5 DCSB
    billie 5100's front @ .85"
    Just as a point of reference - you can bypass the shifter lock manually in this situation. On your shifter cover, there's a little square plate above the "P" on the gear indicator. Pop that plate up and press the button inside down with a screwdriver. While the button is pressed you can get the shifter out of park and into gear.
  3. Jan 12, 2016 at 8:33 AM
    #483
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    Thanks. I was able to do that but my tail lights were out becuase of the popped fuse so i didnt want to drive that way.
    Slashaar likes this.
  4. Jan 12, 2016 at 8:47 AM
    #484
    adrenalnjunky
    completely understandable - good looking truck. Love the build.
  5. Jan 12, 2016 at 9:30 AM
    #485
    mferguson
    mferguson Well-Known Member
    Marc
    2011 Tacoma TRD Sport
    This is why I love my dakar packs...Keep them at full height! mine took a long time to settle... It would settle faster the more you wheel it:broccoli:image2.jpg
  6. Jan 12, 2016 at 3:14 PM
    #486
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    maybe the middle lugs are stickign out more than the side lugs, causing it to rub more with a wider stace
    maybe try airing them down a little?
    ragincajun35[OP] likes this.
  7. Jan 12, 2016 at 3:46 PM
    #487
    cjacob
    cjacob Well-Known Member
    Lafayette, La
    '05 PreRunner SR5 TRD
    Mine was disabled like that not long ago from a blown fuse, I grounded a wire for my MTS by mistake and it blew an ABS related fuse. Truck is looking great, sometimes it takes me a minute to realize it's you driving by because I'm not used to the new one and by the time I realize you waving I'm already past you.
  8. Jan 12, 2016 at 3:52 PM
    #488
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Saw the rubbing issue.....caster adjustments move the tires which way?
  9. Jan 12, 2016 at 5:57 PM
    #489
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    Your truck is sick dude thanks for the input
    mferguson[QUOTED] likes this.
  10. Jan 12, 2016 at 6:00 PM
    #490
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    Caster is the angle that the shock is forward and back. So chopper or shopping cart if that makes sense.
  11. Jan 12, 2016 at 6:01 PM
    #491
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    I ended up taking the spacers off. No use creating problems for myself. My truck rides and wheels great without them so.... Off they go. Already have em sold!
    99TacoDriver and Acerwin like this.
  12. Jan 12, 2016 at 6:02 PM
    #492
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    That's cool that they're already sold! Someone is always wanting spacers
  13. Jan 12, 2016 at 6:04 PM
    #493
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    Free floor mats are awesome!! :D
    Also check fitted my new CB antenna mount from BAMF. I think it fits great. Hope I can get my SWR right at this spot. May have trouble as I am always putting stuff on and off if my rack. When I do a front bumper again I will run the antenna there. Need to paint it and run my coax cable.
    Slashaar, Volunteer, cjacob and 2 others like this.
  14. Jan 12, 2016 at 6:05 PM
    #494
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Need one of those also
  15. Jan 13, 2016 at 6:10 AM
    #495
    cjacob
    Lafayette, La
    Have you thought about using the stock antenna location?
  16. Jan 13, 2016 at 6:12 AM
    #496
    mferguson
    Marc
    No prob. Love the look of yours. Also like those tires. I kinda wanna snag a set up... How much did you pay for 5?
  17. Jan 13, 2016 at 12:07 PM
    #497
    99TacoDriver
    South Louisiana
    free weather techs?? whaa? how?? i had problems with my weather techs folding up on the outside edges when the door would close. ended up just cutting off the last 2 ridges and its not so bad anymore
    Slashaar and ragincajun35[OP] like this.
  18. Jan 13, 2016 at 12:53 PM
    #498
    TravelinLight
    TravelinLight Well-Known Member
    Hayes
    Pensacola, FL
    Bilsteins on front and rear, OME 885 coils, Wheeler's AAL with overload left in, LR UCA's, Stock TRD 17" wheels, 255/75-17 BFG KM tires, VIPMOTOZ headlights, Lifetime LED headlight bulbs, 6000K LED Fog bulbs, Jumper's Interior and license plate LED's, Husky Classic floor mats, OEM bed mat, Leer100R truck shell with carpeted platform, de-badged, white derped grill emblem.
    So sick! lets get rid of that chrome tho!
  19. Jan 13, 2016 at 9:35 PM
    #499
    yote
    yote Washington State University
    Mark
    Tacoma, WA
    2002 Ext Cab TRD Off-Road
    Gonna take a good long look at this build tomorrow at work :D
    Looks good though!
  20. Jan 14, 2016 at 8:09 AM
    #500
    Volunteer
    Volunteer Well-Known Member
    Larry
    2013 Taco TRD Offroad
    Mats look great, like the antenna bracket just like you mentioned same setup and location as the one I had on the 80. I was always breaking the antenna's on the front bumper and that location worked out much better :thumbsup:
