Turok....Louisiana Dinosaur Slayer Dad Rig Build
Discussion in '2nd Gen. Builds (2005-2015)' started by ragincajun35, Oct 24, 2015.
  1. Apr 3, 2016 at 2:07 PM
    #1201
    ragincajun35
    ragincajun35 [OP] Well-Known Member
    Spencer
    Louisiana
    2015 DCSB MG TRD Offroad
    See Builds....
    Question.....
    So im installing my new BAMF sliders and there is a small black plastic box that is keeping me from installing them. It is about 5"x4" and it is on the outside of the frame directly under the passenger side door. I went look under my neighbors tacoma (2013 DCSB TSS) and he doesn't have it. Im starting to believe that it is something off road specific. Those who have offloads.... do you have this box and do you know what it is? The tag on the cable going into it is part # 82165-04071. HELP!!
  2. Apr 3, 2016 at 2:09 PM
    #1202
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    another day. Im not sure what size tire I'm going to next.
    1) stay 255/85r16
    2) 295/75r16
    3) 305/75r16
    4) 315/75r16
  3. Apr 3, 2016 at 2:19 PM
    #1203
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Bigger is always better
  4. Apr 3, 2016 at 2:20 PM
    #1204
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    whats the biggest i can run on these trail team wheels? (16x7.5)
  5. Apr 3, 2016 at 2:24 PM
    #1205
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    I have the box and it's for the off roads. I'm not sure what it is but since I had mine welded on I just moved mine around it.
  6. Apr 3, 2016 at 2:24 PM
    #1206
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    @loco ran 315's on his with 1.25" spacers all around
  7. Apr 3, 2016 at 2:38 PM
    #1207
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    just on the front or all around? I think he switched to bora .75 spacers eventually
  8. Apr 3, 2016 at 2:40 PM
    #1208
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    He did but I think he rub'd if I remember correctly. And yeah all the way around.
  9. Apr 3, 2016 at 4:39 PM
    #1209
    Thelgord
    Thelgord The Pantagonist
    Augusta, GA
    '13 TRD (OffRoad, 4x4)
    SOS Rocksliders, All Pro skid plate, Procomp add-a-leaf, Bilstein 5100 @ 1.75", CB, high-lift jack
    Apparently it is an accessory cable of some kind, quite extensive through the truck, and expensive. $190-$220 to replace. Came with the Limited Package, Sport and TRD Pro. (Pink Wire in the diagram) Looks like wiring for the AC outlet in the bed, best guess anyway based on the diagram. Here is the link: http://toyota.17vin.com/catalog/674470/allyear/~~~~~~~~~~~~/8/8202G.html
  10. Apr 3, 2016 at 5:33 PM
    #1210
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    35's for the win, but definitely decide on tire size before gears
    ragincajun35[OP] and Acerwin like this.
  11. Apr 3, 2016 at 5:44 PM
    #1211
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Even if you stick with a 33" tire i'd go 4.56 since you'll be towing a overland trailer, give you a bit more power than 4.10
    ragincajun35[OP] likes this.
  12. Apr 3, 2016 at 6:06 PM
    #1212
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    I think i have 3.73s in it now
  13. Apr 3, 2016 at 6:09 PM
    #1213
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    You do. If you go to 35's on them for a bit it's not bad I promise. I'm not saying to stay with it long though cause I am switching my 3rd with @EddyRRT front rear when I buy his cause he's going to SAS his rig.
  14. Apr 3, 2016 at 6:10 PM
    #1214
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    4.56
    I'm running 33s, and I easily tow my trailer.
  15. Apr 3, 2016 at 6:35 PM
    #1215
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    i have towed a little boat behind mine with no issues what so ever. think i will have problems with my adventure/offroad trailer
  16. Apr 3, 2016 at 6:46 PM
    #1216
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Shouldn't until you go up bigger in tires
  17. Apr 3, 2016 at 7:42 PM
    #1217
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    You won't have problems until you are fully loaded and on bigger (or wider, more rolling residence) tires. Depends what you really want to do with the truck though.. More overlanding type or more crawling?
  18. Apr 3, 2016 at 8:04 PM
    #1218
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    more over landing and I'm in no hurry to get anywhere. Just as long as mechanically I'm sound then I'm happy.
  19. Apr 3, 2016 at 8:13 PM
    #1219
    NorthwestCruiser
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Would you be open to 17" wheels or stick with your 16"? If you ran 17" wheels you could go 285/75/17 (34" with 285 width) which would get you clearance but not have the width of a 315.. Or a 295/75/16 would do good too. If you are doing more overlanding then I think a 315 is overkill unless you don't mind the mpg loss and want the looks
  20. Apr 3, 2016 at 8:17 PM
    #1220
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    Yea i really don't see myself going to 315s unfortunately. i love the look but for why i do i can't really justify it. Now if i lived in colorado and wasn't traveling as much as i do then i would prob go to 315s. One day my truck will become a toy and ill get a daily driver. Then Ill go to 35s with long travel and all that shit. But until then ill stick to the 33-34's with stock gears and roll with it! Do they make like a 285/80r16? haha
