Turok....Louisiana Dinosaur Slayer Dad Rig Build
Discussion in '2nd Gen. Builds (2005-2015)' started by ragincajun35, Oct 24, 2015.
  1. Mar 7, 2017 at 10:39 AM
    #1861
    ChadsPride
    Sponsored by TacomaWorld.com
    :woot::woot::woot::woot:
  2. Mar 7, 2017 at 10:45 AM
    #1862
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    Sounds like your at max lift. I'm not an expert by any stretch of the imagination, but you might wanna back those off. What was the ride height on install? Nice choice on the tire.
  3. Mar 7, 2017 at 10:57 AM
    #1863
    ragincajun35
    ragincajun35 [OP] Well-Known Member
    Spencer
    Louisiana
    2015 DCSB MG TRD Offroad
    See Builds....
    Ride heigh at install was 22". I cranked them to 23"
    May have gone too high. I need to figure out a way to lower my rear. TW has me rethinking all my shit. Stayed up last night reading about suspension
    ChadsPride likes this.
  4. Mar 7, 2017 at 10:59 AM
    #1864
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    The long overload can come out without changing the capacity. It will drop. It thickness.
  5. Mar 7, 2017 at 11:30 AM
    #1865
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    3rd from the top?
  6. Mar 7, 2017 at 11:39 AM
    #1866
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    2nd up from the bottom. The long thick flat one.
  7. Mar 7, 2017 at 11:42 AM
    #1867
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    How does that not change the carrying capacity?
  8. Mar 7, 2017 at 11:46 AM
    #1868
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    It's basically a spacer. 3rd from top. Will soften the ride which lowers capacity.
  9. Mar 7, 2017 at 12:09 PM
    #1869
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    This is what I got from Headstrong.
    The OME Dakar leaf pack will provide quite a bit more hauling, towing, and off-road capability over the stock pack. However it will be stiff since you are adding more steel out back but that is the give-and-take in order gain the additional capabilities. The OME pack will provide approx. 2.75”-3” of rear lift over stock. You will maintain the rake of the truck as well. If the overall rear height is too much for you or the ride seems too stiff you can remove the 3rd leaf. Doing so will decrease the spring rate by 15% and the overall height by 15mm. You can also remove the long overload and that will decrease the lift height by ½” but not affect the spring rate. If you feel you need more from the pack there is the OME add-a-leaf which can be added in and that will give you around 15mm of increased lift height and 15% more spring rate. It is not recommended to run the aal just for extra height since the ride from it can be rather stiff if the extra weight is not present.
    ChadsPride and ragincajun35[OP] like this.
  10. Mar 7, 2017 at 12:15 PM
    #1870
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    nice.... who is Headstrong?
  11. Mar 7, 2017 at 12:19 PM
    #1871
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Headstrong off-road. TW vendor of the year 2016.
  12. Mar 7, 2017 at 4:34 PM
    #1872
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    Chopping bodies tonight....:sawzall:
    ChadsPride and raginrougarou like this.
  13. Mar 7, 2017 at 6:38 PM
    #1873
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Sweet. I get a daily reminder to bo mine every day when I back out of my drive way.
  14. Mar 7, 2017 at 6:47 PM
    #1874
    raginrougarou
    raginrougarou Well-Known Member
    Forrest
    2015 Gray Tacoma TRD Sport
    Did that affect your tires at all Juforrest? My cab mounts actually cut at my tires a little bit before I did mine.
  15. Mar 7, 2017 at 6:48 PM
    #1875
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Hasn't yet. It's mostly annoying sounds.
  16. Mar 7, 2017 at 7:45 PM
    #1876
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    Got the passenger side done and ran out of weld wire..... :frusty:
    Came out good. It had me a little nervous there for a little while. The Insain fab CMC requires you to cut a lot of the mount away. Seems rock solid now though. Gotta get some more wire and finish burning in the passengers side and get to cutting away at the driver side. I was supposed to get the tires installed tomorrow but I may wait until I finish the CMC and make any adjustments to my suspension. I think I'm going to drop the front down a bit and also remove an overload leaf from the rear.
    ChadsPride and 99TacoDriver like this.
  17. Mar 7, 2017 at 9:30 PM
    #1877
    BraskaTaco
    BraskaTaco Well-Known Member
    Midwest
    2013 Tacoma TRD OR
    Hell yeah.. can't wait to see the pics.
  18. Mar 9, 2017 at 11:05 AM
    #1878
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Where them tires at?
    ragincajun35[OP] and ChadsPride like this.
  19. Mar 9, 2017 at 1:05 PM
    #1879
    ragincajun35
    Spencer
    Louisiana
    See Builds....
    Got postponed until tomorrow.
  20. Mar 9, 2017 at 1:19 PM
    #1880
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Did you get CMC done?
