Turtle Woodwork
Discussion in 'Garage / Workshop' started by Gen1TacoLady, Feb 14, 2023.
OP is back! this means:
  1. turtle time!
    66.7%
  2. back to work!
    58.3%
  3. time to mow!
    50.0%
  4. time to move to a colder climate!
    25.0%
  5. don't forget about that locus wood!
    25.0%
  6. yes!
    58.3%
  7. something else!
    33.3%
Multiple votes are allowed.
  1. Mar 20, 2023 at 1:58 PM
    #961
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    :popcorn:
  2. Mar 20, 2023 at 3:51 PM
    #962
    Gen1TacoLady
    Gen1TacoLady [OP] Local favorite
    Pond Princess
    Washington County, MD
    '95 Red Tacoma
    First time with the rabbeting bit. :thumbsup:
  3. Mar 20, 2023 at 4:24 PM
    #963
    PhoenixFire
    PhoenixFire Well-Known Member
    SoCal
    2023 Ice Cap Tacoma TRD OR
    I'm sorry to laugh, but this almost made me spit my drink out! To be clear, I'm not laughing at you, it's the situation, because I can total see where you're coming from!:rofl:
    Some tips for using a random-orbit sander from a novice who is still learning:
    • Hook up a dust collector to keep the sanding pad clean. Those dust "collection" bags are a joke. It's not just to keep the air clean, but also to pull dust off your work surface.
    • You want to make sure nothing gets between the sanding disc and the surface of your board. Any little spec of debris can cause swirls as it's dragged across the surface.
    • Push down with just enough pressure to keep the sander level, and let the sander do the work. Too much pressure may reduce the life of the motor and also may cause the sander to dig in to your work surface.
    • Sand along the grain in long, steady passes from one end of your work piece to the other. Avoid circular and/or back and forth motions. Each pass slightly overlapping the previous pass. This keeps consistency and helps prevent sanding deeper in certain areas more than others.
    • Use the side of a pencil to lightly mark wave patterns over your work surface. Not only will this give you visual cues where you've sanded, it'll show you areas that aren't flat and need more attention. When the pencil marks are gone, it's time to move to the next higher grit.
    • Vacuum/Dust off your work surface between sanding to reduce the amount of loose sand particles being dragged by the next sanding.
    My apologies if this has been mentioned before.
    Side note: I'm just using a cheap Bauer random-orbit sander I picked up from Harbor Frieght. I slpurge on better quality sanding discs!
    Stumpy Nubs has a good video on this:
    https://www.youtube.com/watch?v=0uvX4Xm2Y0I
  4. Mar 20, 2023 at 5:28 PM
    #964
    Gen1TacoLady
    Pond Princess
    '95 Red Tacoma
    :D:D:D:fistbump::fistbump:
    Good points. Thank you. :)
    I've got a lot to learn about sanding. :anonymous:
  5. Mar 20, 2023 at 5:33 PM
    #965
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  6. Mar 20, 2023 at 6:27 PM
    #966
    PhoenixFire
    SoCal
    Mr. Miyagi needs to update his lessons for power tools.
  7. Mar 20, 2023 at 6:29 PM
    #967
    PhoenixFire
    SoCal
    Don't we all!
    Any time. Glad to help! :hattip:
  8. Mar 20, 2023 at 6:38 PM
    #968
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
  9. Mar 20, 2023 at 6:40 PM
    #969
    PhoenixFire
    SoCal
    The wife makes baby blankets for family, friends, and co-workers. She had a request for a Thin Blue Line flag.
    The baby's name is Leo, BTW... As in Law Enforcement Officer lol
  10. Mar 20, 2023 at 6:43 PM
    #970
    Gen1TacoLady
    Pond Princess
    '95 Red Tacoma
    :101010::101010::101010:
    I plan to make some of those too! :fistbump:
  11. Mar 20, 2023 at 7:12 PM
    #971
    Gen1TacoLady
    Pond Princess
    '95 Red Tacoma
    Sure is!!! :fistbump:
  12. Mar 20, 2023 at 7:15 PM
    #972
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
  13. Mar 20, 2023 at 7:17 PM
    #973
    Gen1TacoLady
    Pond Princess
    '95 Red Tacoma
    :rofl::rofl:❤ ❤ :):)
  14. Mar 21, 2023 at 1:11 AM
    #974
    Pibbles99
    Pibbles99 One more cast
    Brian
    Southern NH
    21 OR dbl cab
    This just in . Thanks Mollie
    Redeemed, wilcam47, Delta09 and 7 others like this.
  15. Mar 21, 2023 at 1:14 AM
    #975
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    I like the red and brown square one . Wish I did that. But I’m very happy with what I have now :D
  16. Mar 21, 2023 at 1:15 AM
    #976
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    It’s very nice thanks
  17. Mar 21, 2023 at 1:16 AM
    #977
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    Good morning Mollie and John, guess I’ll get up now
  18. Mar 21, 2023 at 4:22 AM
    #978
    Gen1TacoLady
    Pond Princess
    '95 Red Tacoma
    :woot::woot::woot:
    That looks like it fits real well! Thanks for sharing Brian!! :):):)
  19. Mar 21, 2023 at 4:23 AM
    #979
    Gen1TacoLady
    Pond Princess
    '95 Red Tacoma
    I'm trying to decide whether to let that one be a regular board or give it handles and make it a tray. :notsure:
  20. Mar 21, 2023 at 4:24 AM
    #980
    Gen1TacoLady
    Pond Princess
    '95 Red Tacoma
    Morning Brian, I hope you get rest today. Sounds like you could use some. :)
