Turtle Woodwork
Discussion in 'Garage / Workshop' started by Gen1TacoLady, Feb 14, 2023.
  1. Mar 21, 2023 at 6:04 PM
    #1021
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Those actually interest me... Hmm...
    @Gen1TacoLady I would imagine a spar varnish on those would make them hold up to being coasters. I do have a compressor and spray gun to make quick work of that :anonymous:
  2. Mar 21, 2023 at 6:07 PM
    #1022
    Gen1TacoLady
    Gen1TacoLady [OP] Local favorite
    Pond Princess
    Washington County, MD
    '95 Red Tacoma
    They have spar varnish on them, so Troy can tell us how they hold up.
    I should probably make a few more. :)
  3. Mar 21, 2023 at 6:09 PM
    #1023
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I like to spray my finishes when I can. They sell spray cans of the spar and regular poly, but I mix mine "hot" to dry faster. Doesn't work so great with a gloss though.
  4. Mar 21, 2023 at 6:46 PM
    #1024
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    That spar finish is awesome. Not sure how long it will last but its pretty much sealed forever on a coaster
  5. Mar 22, 2023 at 1:29 AM
    #1025
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    There is another option to felt-sheets ... flocking (seriously called "flocking"). You buy the color you want from the company named on the can ... glue color matches the powder. Spread the glue, then used the tube to "push" the powder out and seals against the glue. You have technically 10 minutes from glue exposure to air to "locked in", but I found 5 minutes is more realistic. If you experiment you may find a way to use all 10 minutes. Flocking is what jewelry cases and gun cases use to prevent rubbing against hard woods.
    Here is a nightstand I wanted. I spent much time designing the side flip-downs to store an item I wanted easy access to in the middle of the night. Also "just because" ... you can understand that. The flocking started as a color contract (the color is "Wine", but they make "red", "forest green", "blue", "yellow" ...) against the whiter wood. Design was considered but I caved in a little on quality because I wanted the table. You can see how I still need practive applying the flocking.
    Close up of the flip-down you can see the special structure I built (two thin pieces, blocks in the middle) and you can see how flocking adapts to complex shapes the way felt padding does not easily.
    Finally the leg bottoms ... 1x3 poplar that is embedded in the 2x2 poplar legs with 45 degree slits.
    Just for grins ... two other projects. First is my attempt at a serving tray. Poplar mostly, walnut and white oak alternating in the middle.
    And a towel rack. Was renting a house, needed a towel rack closer to the shower and did not have the right to put something in the wall. Overlapping joints allow 3 dowel bars, 4 ft wide. Can hold 3 full size towels or 2 full-size and 2 hand towels.
  6. Mar 22, 2023 at 1:42 AM
    #1026
    RichochetRabbit
    Purple Wood is just too cool!
  7. Mar 22, 2023 at 1:48 AM
    #1027
    RichochetRabbit
    Stop using 60-grit sandpaper!
    916carl, johneman, wilcam47 and 2 others like this.
  8. Mar 22, 2023 at 1:53 AM
    #1028
    RichochetRabbit
    Your skill with finishing is impressive. I get within 90% at best on finishing, then I give up and settle for a practical "good enough".
    I am jealous.
  9. Mar 22, 2023 at 2:00 AM
    #1029
    Pibbles99
    Pibbles99 One more cast
    Brian
    Southern NH
    21 OR dbl cab
    120
  10. Mar 22, 2023 at 2:01 AM
    #1030
    Pibbles99
    Brian
    Southern NH
    21 OR dbl cab
    Morning everyone
  11. Mar 22, 2023 at 4:02 AM
    #1031
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    This is what my stove top look like.
    I had to cut out the counter to install this range. Took a loss on counter space
    By cutting holes, I think stiff will have a chance to spill underneath the cover. I'm going to use a flat edge to line up with the burners and see if height a issue.
  12. Mar 22, 2023 at 4:03 AM
    #1032
    Venom
    Kevin
    Massachusetts
    Good morning, everyone!
    wilcam47 and Gen1TacoLady[OP] like this.
  13. Mar 22, 2023 at 4:04 AM
    #1033
    Venom
    Kevin
    Massachusetts
    Frigidaire Gallery, stainless.
  14. Mar 22, 2023 at 4:06 AM
    #1034
    lynyrd3
    Bill
    East Central Upstate NY
    Morning Mollie
  15. Mar 22, 2023 at 4:52 AM
    #1035
    Gen1TacoLady
    Pond Princess
    '95 Red Tacoma
    First of all...welcome :hattip:
    Secondly, I have never heard of flocking before. I interesting. :)
    And third, nice work! :fistbump:
    johneman and wilcam47 like this.
  16. Mar 22, 2023 at 4:53 AM
    #1036
    Gen1TacoLady
    Pond Princess
    '95 Red Tacoma
    :anonymous:
    :anonymous::anonymous:
  17. Mar 22, 2023 at 4:54 AM
    #1037
    Gen1TacoLady
    Pond Princess
    '95 Red Tacoma
    Thank you kindly. :):):)
  18. Mar 22, 2023 at 4:54 AM
    #1038
    Gen1TacoLady
    Pond Princess
    '95 Red Tacoma
    Morning John :hattip:
    johneman, wilcam47 and Taco critter like this.
  19. Mar 22, 2023 at 4:55 AM
    #1039
    Gen1TacoLady
    Pond Princess
    '95 Red Tacoma
    Morning Brian :hattip:
  20. Mar 22, 2023 at 4:57 AM
    #1040
    Gen1TacoLady
    Pond Princess
    '95 Red Tacoma
    Oh! Ok, I gotcha. Is there a gap between the range and the sides? I wonder if you could put a lip on the underside to keep a cover in place. :notsure:
    Venom[QUOTED], johneman and wilcam47 like this.
