Turtle Woodwork
Discussion in 'Garage / Workshop' started by Gen1TacoLady, Feb 14, 2023.
What color should @delta09 paint his house?
  1. Black
    0 vote(s)
    0.0%
  2. Purple
    0 vote(s)
    0.0%
  3. Hot pink
    28.6%
  4. All of them
    14.3%
  5. Whatever chartreuse is
    28.6%
  6. Invisible
    14.3%
  7. Camo
    42.9%
  8. Polka dot
    28.6%
  9. Plaid
    57.1%
Multiple votes are allowed.
  1. Apr 6, 2023 at 11:42 AM
    #1561
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    Keep up the good work!!!! :wave:
  2. Apr 6, 2023 at 11:42 AM
    #1562
    Squirt
    Squirt Samsung Aficionado!
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back with a 3in Speedys Snap resonator. J&L catch can. AMP Powersteps
  3. Apr 6, 2023 at 12:47 PM
    #1563
    Gen1TacoLady
    Gen1TacoLady [OP] Local favorite
    Pond Princess
    Washington County, MD
    '95 Red Tacoma
    Can you do it like David Attenborough? :fingerscrossed:
    StayinStock and johneman like this.
  4. Apr 6, 2023 at 12:48 PM
    #1564
    Gen1TacoLady
    Pond Princess
    '95 Red Tacoma
    Fellas! How's your day? :popcorn:
  5. Apr 6, 2023 at 12:59 PM
    #1565
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
    It was around $65 back then. Now it's almost $90.
    I needed it for the air compressor.
    Gen1TacoLady[OP] likes this.
  6. Apr 6, 2023 at 1:00 PM
    #1566
    Squirt
    Ben
    Pretty good. Yours?
  7. Apr 6, 2023 at 1:01 PM
    #1567
    Gen1TacoLady
    Pond Princess
    '95 Red Tacoma
    Certainly better than yesterday.
    I got me a table top today! :bananadance::bananadance::bananadance:
  8. Apr 6, 2023 at 1:03 PM
    #1568
    Squirt
    Ben
    Sweet!
  9. Apr 6, 2023 at 1:17 PM
    #1569
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    While David Attenborough works on the script ... a genuine suggestion. If you heard this already, please forgive. If not, I hope this helps.
    I heard from someone somewhere that angles can be made less tricky if you do not expect perfection from the cut. Even a chopsaw can wiggle/travel on its axis a little skewed. The technique I heard was to intentionally undercut a 45 degree angle instead of trying to exactly cut. Kerf will catch up to you. Instead of trying 45, cut 44 and compensate on the bottom side of the 45 to leave a little more of the acute angle part to adjust as required. If the axis is off and it overcuts, 44 becomes your intended 45. If it cuts exactly 44, you can carefully manually adjust the joints because you saved some material.
  10. Apr 6, 2023 at 1:20 PM
    #1570
    RichochetRabbit
    I have 15-ish ft of 12/3 extension cord. Pricier than most cords, but can handle "full normal room" load.
  11. Apr 6, 2023 at 1:25 PM
    #1571
    johneman
    johneman Life is good relaxin' on the porch!!
    Ken
    Warwick,Bucks PA
    2021 TRD OR Magnetic Gray
    Go Rhino Dominator D1 step, Extang Encore Tonneau.
    What he said :eek:
  12. Apr 6, 2023 at 1:33 PM
    #1572
    SACTOWN
    Greg
    Pretty good I guess yours?
  13. Apr 6, 2023 at 2:11 PM
    #1573
    Gen1TacoLady
    Pond Princess
    '95 Red Tacoma
    I did hear something like this I think, but I havent tried it yet. I also heard putting a shim under the pieces when you cut will help keep the front seem tighter as well.
    Thanks for sharing! I do appreciate it. :):thumbsup:
    johneman and wilcam47 like this.
  14. Apr 6, 2023 at 2:15 PM
    #1574
    Gen1TacoLady
    Pond Princess
    '95 Red Tacoma
    Still happening. Got my table top put together so I'm pleased. :)
  15. Apr 6, 2023 at 2:20 PM
    #1575
    Gen1TacoLady
    Pond Princess
    '95 Red Tacoma
    Garden basket.
  16. Apr 6, 2023 at 2:23 PM
    #1576
    PhoenixFire
    PhoenixFire Well-Known Member
    SoCal
    2023 Ice Cap Tacoma TRD OR
    A playing card works well for the shim. Place it against the fence nearest the blade.
  17. Apr 6, 2023 at 2:26 PM
    #1577
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Thats purdy!!
  18. Apr 6, 2023 at 2:35 PM
    #1578
    Venom
    Kevin
    Massachusetts
    I have a few 20 Amps outlets that I use for the compressor. The long cord allows me to bring the compressor outside, where ever needed. I didn't want a long compressor hose. It's a 8 gallon compressor. The bigger compressor is stationary.
    If I'm close to the 20 Amp outlet then I'll use the 15ft cord if needed.
  19. Apr 6, 2023 at 2:50 PM
    #1579
    Gen1TacoLady
    Pond Princess
    '95 Red Tacoma
    Thanks Bob! ❤
    Paint? :notsure:
    wilcam47 and johneman like this.
  20. Apr 6, 2023 at 6:28 PM
    #1580
    RichochetRabbit
    Observe, if you will, the wild Speckled Woodworker. Driven on by the irresistible and primal need to gather materials from her surroundings and create perfectly manicured reflections of her world view with those few meager offering made to her by Mother Nature. And though her creations may be inexplicably random and almost always flawed, she seems undeterred in her tireless efforts.
    Notice the way she lines up the various twigs, rocks and sticks in patterns that, in a human, would appear to indicate a plan beyond, or below, our understanding. Notice how she rearranges her collection into primitive geometric patterns, somehow almost calculating what might be called symmetry, if she could only use correct techniques. She chews one one twig, then the other, trying to make them the same size. But she does not put them beside each other and cut both at the same time, as human craftsman have learned. She instead alternately chews each seeking only to measure the length with her eyes and only the length beyond her mouth. She does not notice that the bite itself is making matters worse, even when both sticks are becoming, as they can only inevitably be, reduced to useless bits.
