[Tutorial] How to Replace a Belt Tensioner, Idler Pulleys & Serpentine Belt on a 2005-2015 V6 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by UnoriginalName, Nov 7, 2024.
  1. Feb 9, 2025 at 8:37 AM
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
  2. Feb 9, 2025 at 9:02 AM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    I just did this with Gates idler pulleys and replaced the tensioner pulley bearing with the Nachi bearing. Not terribly difficult. Would have been way harder to replace the entire tensioner.
  3. Mar 18, 2025 at 1:34 PM
    KittenCarrier
    KittenCarrier Stop honking, I'm crying
    Dustin
    Charlottesville, VA
    2015 Tacoma DCSB TRD Sport
    Current: -OME 3" full suspension lift w/ HD springs -Diff drop, sway bar relocate, driveshaft spacer -JBA UCAs -CVJ offroad OEM CVs -RCI sliders and full skids (LCAs, engine, transmission, x-fer case, x-member) -Prinsu roof rack -KB Voodoo 18" longbed modular bedrack -Smittybilt XL RTT -Cali Raised LED ditch lights and pod lights -CB and HF winch Planned: -285/70/17 soon... 285/75/17 curious. Keeping stock 17x7.5 wheels (spaced 1.25") -Rear and front Eaton E-lockers -Regear to 4.11 or 4.56 (depends on if I go to 34s) -ARB front bumper -Outgear Solutions rear tube bumper
    Have 208k miles on my 2015 v6, and I have some growling in the tensioner pulley when I turn on the AC.
    I’m trying to take this truck to 400k miles, and I’m debating if I should swap just the pulley or the entire tensioner like OP. I also need to install a new alternator (rpm whine at higher rpms when AC is on) and would be able to take care of that at the same time. It’s just that dealing with the AC compressor doesn’t look like fun.
    Any advice is appreciated here - I guess my question is: Do tensioners (spring or other components) tend to fail with enough miles, or is addressing the pulley good enough to keep the truck happy?
  4. Mar 19, 2025 at 3:00 PM
    KittenCarrier
    Dustin
    Charlottesville, VA
