TW Live
  1. Dec 21, 2012 at 2:56 PM
    trdNick
    trdNick Odie
    Texas
    2020 Ram 1500 4x4 5.7 Hemi BigHorn
  2. Dec 21, 2012 at 2:57 PM
    Enigmaaron
    Enigmaaron All your soul are belong to us
    PA
    1st gen superiority
    Why would you put a spacer on top of an adjustable coilover? :confused:
  3. Dec 21, 2012 at 3:01 PM
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    i think it gets stiffer anyways the only thing the spacer does is change shock droop to stuff measurments
  4. Dec 21, 2012 at 3:06 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    he's hawaiin
  5. Dec 21, 2012 at 3:26 PM
    rctoy
    konstantenos
    Pocatello Idaho
    Ohh see you left out details.
  6. Dec 21, 2012 at 3:34 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    Fat. Deep fried hamburgers are really good!
  7. Dec 21, 2012 at 3:36 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
  8. Dec 21, 2012 at 3:38 PM
    Alexb03
    Alexb03 Well-Known Member
    Alex
    New Mexico
    06 Tacoma Double cab
    3" lift, 285/75/16, navigation,
    Hit a bird had to tape my grill to get home without it flying off
  9. Dec 21, 2012 at 3:40 PM
    Alexb03
    Alex
    New Mexico
    New grill, should I leave it or satoshi it again??
  10. Dec 21, 2012 at 3:45 PM
    rctoy
    konstantenos
    Pocatello Idaho
    FAT is right.
  11. Dec 21, 2012 at 3:48 PM
    DLAV
    DLAV Well-Known Member
    Denis
    SK
    12 DCLB Barcelona Red
    N-Fab Steps, Weathertech floor mats, Oem Bed mat
  12. Dec 21, 2012 at 3:50 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    !!! Lots of freebies too. Free hat, DVDs, lube, and stickers!
  13. Dec 21, 2012 at 3:52 PM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    lmao. i’m good :D i don’t think i will ever be fat.
    it was for another thread.
  14. Dec 21, 2012 at 4:08 PM
    Tacoma831
    Tacoma831 Member
    Santa Cruz, CA
    08 Tacoma Sport 4x4
    OME 886 Coils, OME Shocks, OME Dakars, Snug Top, De-Badged, ARB Bullbar, XRC8 Winch
  15. Dec 21, 2012 at 4:16 PM
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
  16. Dec 21, 2012 at 4:19 PM
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    that's some mighty strong glue ya got there.
  17. Dec 21, 2012 at 4:21 PM
    Enigmaaron
    PA
    1st gen superiority
    If the ride height is the same you haven't changed the preload, if the ride height is higher then you have increased the preload, regardless of how you have done it. Unloaded the bottom of the coilover is a stationary point, you have moved the top of the spring (and increased preload) by moving the top of the coilover down rather than the top of the spring alone. What you have done is change the range of travel of the shock piston in relation to the suspension. And likely outside of the designed range.
    This. Your droop is limited by the shock (I believe). By lowering the shock you have increased the potential droop, however if you have stock UCAs you are likely over extending them at droop now causing potential failure.
    Here's where the problem is. Yes you have potentially limited your up travel (maybe not depending on how much play the shock is designed with). But you have done this by making the limit the shock rather than the bump stops. This is bad, the shock is not designed for this. One bad pothole/speed bump and you could blow out the shock.
  18. Dec 21, 2012 at 4:36 PM
    jrzyshore
    jrzyshore Well-Known Member
    Scott
    SNJ
    2010 Toyota Prius TRD Offroad
    Icon extended travel coilovers and rear shocks, Dakar leaf springs, Toytec U bolt flip, extended length Icon 2.0 rear shocks, Timbren Bump stops ,TC UCAs, Street Taco (Beefedtaco) 1 1/2" CB drop, 4x Innovation DOM tube sliders with kick outs, some extended brake lines,ATO front skid plate, ATO trans skid, ATO Hi Lift brackets, 60" Hi Lift jack and a pine tree air freshener.
    Where did you find that I will have to give it a try.
  19. Dec 21, 2012 at 4:37 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Didn't know you got Yuengling out there - That's a Pennsylvania beer. Oldest brewery in the US
  20. Dec 21, 2012 at 4:39 PM
    Socalduckslayer
    Socalduckslayer Pelfreybilt Off-Road
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    Tasty stuff.
    The brewery is here in San Diego, super cool place. The stone work in the restaurant is something else. Good food, good beer, amazing surroundings.
