TW Live
  1. Feb 9, 2013 at 12:16 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    muuuch better
    but i had terrible vibes from multiple factors...dented shaft and failing carrier bearing..video on my build of how bad it was..
    amazing how much crap i had to deal with with that failing setup...some clunking is gone, vibs are gone, start up in 1st is smoother...
    old one is in storage now until i get some $ together to rebuild it and have a proper spare
  2. Feb 9, 2013 at 12:17 PM
    ToyComa92
    ToyComa92 Write your love, Then your anger.
    Jon
    Conifer, Colorado
    2006 Tacoma TRD sport Debadged
    Heated katzskin leather, Black TRD sport wheels, Bilstein 5100s, Toytec 2" Springs, Deaver 2" AAL, Pioneer AVH4400BH, Ultragauge, Weathertechs front/rear,
    Just about to turn 130,000 on an 2006. not bad for 7 years but i wish it was still in the five digit area haha.
  3. Feb 9, 2013 at 12:24 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    I'd say it's normal wear then IMO. Many have had them go with much less mileage. I would not be concerned.
  4. Feb 9, 2013 at 12:34 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
  5. Feb 9, 2013 at 12:34 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    i'm around 120k and mine was in bad shape...not completely failing but it was sloppy..
    it aged fast toward the end though because a dented shaft made the rotation very harsh on the carrier bearing and ujoints..
  6. Feb 9, 2013 at 12:36 PM
    jjew18
    Alliance Airport
    05 PreRunner SR5
  7. Feb 9, 2013 at 12:44 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
  8. Feb 9, 2013 at 12:46 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    DAFUK?! Only I can be missing one random trans pan fastener :facepalm:
  9. Feb 9, 2013 at 12:48 PM
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    Tractor 1. Nemo 0
  10. Feb 9, 2013 at 12:54 PM
    XXXX
    sKiP
    05 Prius
    you got a gremlin going around stealing bolts off your rig or something?
  11. Feb 9, 2013 at 12:59 PM
    MonkeyProof
    SoCal- SGV
    That gremlin works fast lol..was there Thursday evening when I had it up in the air prepping for my KOH trip...
  12. Feb 9, 2013 at 1:08 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
  13. Feb 9, 2013 at 1:08 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
  14. Feb 9, 2013 at 1:08 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
  15. Feb 9, 2013 at 1:10 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
  16. Feb 9, 2013 at 1:26 PM
    tmreyes1
    tmreyes1 Well-Known Member
    T-Rey
    TX
    2017 TRD
    Is that before or after cleaning
  17. Feb 9, 2013 at 1:29 PM
    MonkeyProof
    SoCal- SGV
    Are you replacing the studs as well?
  18. Feb 9, 2013 at 1:30 PM
    XXXX
    sKiP
    05 Prius
    hope so
  19. Feb 9, 2013 at 1:36 PM
    ajohnson
    Andy
    Charlotte, NC
    Yup, ARP studs. Also got ARP hub studs :D
  20. Feb 9, 2013 at 1:41 PM
    MonkeyProof
    SoCal- SGV
    Nice..important for the nuts to be properly torqued with a torque wrench otherwise the cone thingys will end up working themselves loose. And thats usually the number one reason why the studs break in the first place, even with ARP studs
