TW Live
  1. Feb 9, 2013 at 1:42 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    Would you say this Jerry can is no good? Or does it have a life still?
  2. Feb 9, 2013 at 1:44 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    many many years of life left
    POR-15 Motorcycle Fuel Tank Repair Kit
    Item #13432 ZP
    In Stock - Ready to Ship Today
    Only $39.99
    Cycle Tank Repair Kit cleans, prepares and seals smaller fuel tanks in motorbikes, cycles and more
    If that the old gas tank you're restoring has gum, varnish or sludge inside, it has to be removed first. This POR-15® Cycle Tank Repair Kit is specially formulated for the special needs of small fuel tanks such as those on motorbikes, 4-wheel RVs, snowmobiles, outboards, generators, etc.
    • Marine Clean™ removes gum, sludge, varnish
    • Prep & Ready™ removes rust and prepares tank for sealer
    • US Standard Tank Sealer™ permanently seals the tank
    • Cloth Patch seals large holes or reinforces weak areas
    • Brush applies patching system to exterior of tank
  3. Feb 9, 2013 at 1:57 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    :thumbsup: I have been checking the torque before, after, and even during each trail ride. I am putting in Longfields and the trunnion eliminator, so I figured I will upgrade as much as possible while it is apart :D I got the steering arm stud kit from FROR, it also came with nylon locknuts
  4. Feb 9, 2013 at 2:18 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Sweet!
    Did you get the cromo inner hub gears as well?
  5. Feb 9, 2013 at 2:22 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
  6. Feb 9, 2013 at 2:22 PM
    ajohnson
    Andy
    Charlotte, NC
    chromo inner and outers :cool: got them during the TG sale a while back. Been stocking parts for a while.
  7. Feb 9, 2013 at 2:26 PM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
  8. Feb 9, 2013 at 2:30 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
  9. Feb 9, 2013 at 2:30 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    top on is cleanish, bottom is dirty. I'm gonna work on these all day. :/
  10. Feb 9, 2013 at 2:34 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Wd-40 and wire brush ftw!
  11. Feb 9, 2013 at 2:40 PM
    PLC721
    Patrick
    Chandler, Az
  12. Feb 9, 2013 at 2:46 PM
    PLC721
    Patrick
    Chandler, Az
    Scrubbed down the kings as well
  13. Feb 9, 2013 at 2:50 PM
    SoutheastTaco
    SoutheastTaco Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
    How do these look?
  14. Feb 9, 2013 at 3:06 PM
    trdNick
    trdNick Odie
    Texas
    2020 Ram 1500 4x4 5.7 Hemi BigHorn
    Not bad for $5
  15. Feb 9, 2013 at 3:22 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
  16. Feb 9, 2013 at 3:22 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
  17. Feb 9, 2013 at 3:22 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
  18. Feb 9, 2013 at 3:23 PM
    XXXX
    sKiP
    05 Prius
    650# springs? thats a good deal of preload
    I wouldn't accept it nor want my truck aligned to those specs. In the end it all depends on your uses and mods.
  19. Feb 9, 2013 at 3:24 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
  20. Feb 9, 2013 at 3:26 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
