TW Live
  1. Jul 10, 2013 at 6:46 AM
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    I just spent five minutes looking at TimmyB's sig... :anonymous:
  2. Jul 10, 2013 at 7:16 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    For Lisa! *You need a Storm trooper sticker. Sent from my Verizon Wireless 4G LTE Smartphone
  3. Jul 10, 2013 at 7:56 AM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
  4. Jul 10, 2013 at 7:57 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Really? This?
    You sick bastard.
  5. Jul 10, 2013 at 7:58 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    :rofl:
  6. Jul 10, 2013 at 8:04 AM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    New rotors and pads
  7. Jul 10, 2013 at 8:04 AM
    jrzyshore
    jrzyshore Well-Known Member
    Scott
    SNJ
    2010 Toyota Prius TRD Offroad
    Icon extended travel coilovers and rear shocks, Dakar leaf springs, Toytec U bolt flip, extended length Icon 2.0 rear shocks, Timbren Bump stops ,TC UCAs, Street Taco (Beefedtaco) 1 1/2" CB drop, 4x Innovation DOM tube sliders with kick outs, some extended brake lines,ATO front skid plate, ATO trans skid, ATO Hi Lift brackets, 60" Hi Lift jack and a pine tree air freshener.
    :rofl::rofl:
  8. Jul 10, 2013 at 8:14 AM
    JLink
    Josh
    Ocean, NJ
    Need some plumbing advice.
  9. Jul 10, 2013 at 8:16 AM
    JLink
    Josh
    Ocean, NJ
    Need some plumbing advice. I want to make my washer drain less ghetto. I'm thinking if I take the cap off the T and put it where the T attaches to the rest of the pipe it will eliminate this mess. Then for the drain I want to add to the right on the black plastic pipe in the first picture. I guess that's a clean out where the screw on end is where the black pipe from the far right attaches to the main drain. If I add another Y at the end of that ill still have the end for a clean out and have the washer drain come in on the top of it.
  10. Jul 10, 2013 at 8:16 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
  11. Jul 10, 2013 at 8:29 AM
    guitarjamman
    guitarjamman Well-Known Member
    Zach
    Northeast
    2019 Ram 2500
    If I'm not mistaken and we are both looking at the same items, that "tee" is actually a check valve which prevents water from flowing back into your washing machine. That is needed because you also have sewer/septic running into the same pipe and out into your septic system, without that check valve, you will absolutely get toilet water running into your washing machine drain line.
    Definitely a ghetto setup, but please do not try and remove that cover and tie into it.
  12. Jul 10, 2013 at 8:32 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    My beautiful now painted bed rack
  13. Jul 10, 2013 at 8:33 AM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    Better turn around.
  14. Jul 10, 2013 at 8:34 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
  15. Jul 10, 2013 at 8:37 AM
    JLink
    Josh
    Ocean, NJ
    I'm sure I didn't explain it very well, but you need to look at the first picture too and that's where I want to tie it in. I want to cap off the check valve or remove it and cap off where it was.
    Yea I know I need to check the owners manual for the washer. But if it can go that high, does everything else sound right?
  16. Jul 10, 2013 at 8:45 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    Not to mention the washer line is BEFORE THE HOUSE TRAP
  17. Jul 10, 2013 at 8:51 AM
    jrzyshore
    Scott
    SNJ
    He may have to relocate the washer. You don't see house traps that often anymore.
  18. Jul 10, 2013 at 8:55 AM
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    That looks great! Well done!
  19. Jul 10, 2013 at 8:58 AM
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    I miss my taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow SAS 5” Leafs, high pinion diff, 37” PBRs, MC rear, AP front bumpers, 5.29s, locked
    Burn it to the ground and start over
  20. Jul 10, 2013 at 9:04 AM
    JLink
    Josh
    Ocean, NJ
    I think I'll hold off on all that for now lol.
    City sewer.
    Checked owners manual, washer can pump 96" maximum vertical. And I'm going to have it on a platform so maybe 5' total so the height should be fine to tie it in where the kitchen sink drain comes from far right
    :eek: that bad??!!
    :D
    Did some shingle work last weekend. Installed an attic fan.
