TW Live
  1. Nov 5, 2014 at 3:34 PM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    Springs shouldn't settle then. just throw a 1" block in the back?
  2. Nov 5, 2014 at 3:36 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Probably what I'd do over an AAL. I don't want to go more than an inch of rear lift and the AAL ride isn't worth the extra stiffness since I don't haul much. :anonymous:
    Low Range Offroad has 1" tapered with U bolts for $75.
  3. Nov 5, 2014 at 3:41 PM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
  4. Nov 5, 2014 at 3:44 PM
    teneighty
    Yeah, there you go. It's easy to do as well.
  5. Nov 5, 2014 at 3:47 PM
    T4RFTMFW
    We'll see. Maybe I'll sneak them in when I do rear shocks. Minimal budget for truck fun these days.
  6. Nov 5, 2014 at 3:48 PM
    Manwithoutaplan
    ID
  7. Nov 5, 2014 at 3:49 PM
    T4RFTMFW
  8. Nov 5, 2014 at 3:51 PM
    teneighty
    I hear ya, you shouldn't need extended brake lines. I went up 2 1/2" and didn't need them. You will be fine
  9. Nov 5, 2014 at 3:52 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
  10. Nov 5, 2014 at 3:52 PM
    PLC721
    Patrick
    Chandler, Az
  11. Nov 5, 2014 at 3:52 PM
    PLC721
    Patrick
    Chandler, Az
  12. Nov 5, 2014 at 3:56 PM
    T4RFTMFW
    That's good to hear.
  13. Nov 5, 2014 at 4:09 PM
    la0d0g
    running for the hills
    For crawling not hauling
    You don't want to do AAL because of the ride or something else?
  14. Nov 5, 2014 at 4:12 PM
    T4RFTMFW
    Diminished ride and if I need any lift in the rear it won't be more than 1 inch. I don't carry loads regularly and drive a lot of miles so an AAL isn't likely ideal. Inch block shouldn't cause much problem and while it doesn't add anything to my truck except height, it doesn't hurt much either. That's my thinking, anyway.
  15. Nov 5, 2014 at 4:13 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Really it's not bad at all. I'm running an AAL and 883s, I had more stiffness (giggity) up front from the coils than I did from the back. It'll ease up anyways
  16. Nov 5, 2014 at 4:16 PM
    T4RFTMFW
    I'll have to read. Lot of AAL complaints, so will have to wade through and get a better idea versus a short block.
  17. Nov 5, 2014 at 4:16 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Thanks for the invite fuckers!
  18. Nov 5, 2014 at 4:18 PM
    ERMB
    ERMB Well-Known Member
    2002 Land Cruiser
    Umm...are you still waiting for your alignment? Where's the pics?:p
  19. Nov 5, 2014 at 4:18 PM
    TashcomerTexas
    I find that most people complain about AALs considering they didn't replace their whole leaf pack that's already been shot. Since your truck is newer that shouldn't be an issue with yours. I have no complaints
  20. Nov 5, 2014 at 4:18 PM
    la0d0g
    I guess it depends on what you consider diminished ride. I consider stiffness to be better but I'm not running an AAL. Maybe try to find someone selling an OEM TSB 3 leaf pack and throw that on. I ran 884s w/ 5100s set at 0 with TSB leaf pack and sat almost level. Just a little bit of rake. And the ride was fantastic.
