TW Live
  1. Nov 19, 2015 at 4:14 PM
    Gabassman
    Gabassman Drive it like a 4WD
    Tyler
    Georgia
    Like these? I turned them down from around 8 to 6 on wire speed.
  2. Nov 19, 2015 at 4:15 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Tell your GF TW wants to know where this came from lol
  3. Nov 19, 2015 at 4:21 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    This
  4. Nov 19, 2015 at 4:21 PM
    pinchetaco
    pinchetaco Well-Known Member
    Winston Salem, NC
    06 Taco 6 inch ProComp Lift 35's
    6 inch ProComp Lift, 35s, ProComp Wheels, 4.88 gears, Debadged, BHLM, Dome Light Mod, Trailer Plug Relocated
    Dat heat
  5. Nov 19, 2015 at 4:24 PM
    pinchetaco
    Winston Salem, NC
    I'm no expert welder or anything but it doesn't seem like the welds are penetrating that well
  6. Nov 19, 2015 at 4:55 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    And... Cue 3rd gen owners Butthurt comments
    Lame that there's no front rail for tie downs.
  7. Nov 19, 2015 at 5:14 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    It's nice of them to leave a gap for it and the bolts to use to hold it in. That must come with a higher model..
  8. Nov 19, 2015 at 5:15 PM
    Gabassman
    Tyler
    Georgia
    I'm calling it a night on the welding gonna pick it back up tomorrow. How do I know if the beads are penetrating?
  9. Nov 19, 2015 at 5:26 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    You won't penetrate on anything over thin sheet metal with a harbor freight 90 amp.
  10. Nov 19, 2015 at 5:29 PM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
  11. Nov 19, 2015 at 5:36 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
  12. Nov 19, 2015 at 5:36 PM
    Gabassman
    Tyler
    Georgia
    Did some reading online and the best angle for penetration is 0-10* from perpendicular of base metal. The angle I'm at is in the range of 45-60*. Plus I'm welding on metal towards the upper ends of the weldable spectrum.
  13. Nov 19, 2015 at 5:52 PM
    ERMB
    ERMB Well-Known Member
    2002 Land Cruiser
    Saw this while I was out tonight shopping for my Secret Santa
    scottalot and 14489 like this.
  14. Nov 19, 2015 at 5:56 PM
    WildLand
    WildLand Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    What is on top?? Beer gatling gun?
  15. Nov 19, 2015 at 6:16 PM
    ERMB
    2002 Land Cruiser
    I think it was a t-shirt cannon. I gussets it's more of a promotional project but man they had some money in it. All King long travel suspension. Was pretty bad ass, could definitely be a fun ride :p
    scottalot likes this.
  16. Nov 19, 2015 at 7:00 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  17. Nov 19, 2015 at 7:25 PM
    pinchetaco
    Winston Salem, NC
    do some research online. I'd say with two pieces of metal you'd want the bead to look as if it is actually bonding. I'm no expert tho and I'm sure someone else could chime in.
    I'd also have to agree with this. How thick is that metal?
    maybe start a weld thread and see if you can get some good pointers.
  18. Nov 19, 2015 at 7:52 PM
    Gabassman
    Tyler
    Georgia
    It's 1/8 inch. Welds from 18 gauge to 3/16
    ImplicitlyAlberta likes this.
  19. Nov 19, 2015 at 8:35 PM
    ImplicitlyAlberta
    David
    edmonton
    I'd find some scrap 3/16 and give her a go. Might be a good way to learn but I wouldn't use it for heavy duty welding.
  20. Nov 20, 2015 at 4:14 AM
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    Good morning leftovers...
    T4RFTMFW, tcBob[OP] and scottalot like this.
