TW Live
  1. Mar 23, 2016 at 11:46 AM
    Josh828
    Josh828 Well-Known Member
    Josh
    Avery NC
    14 White TRD Off road, Mid travel mountain truck
    FOX 2.5 extended travel, Fox 2.0 rears, LR UCA, XSPX rims, some light bars, and switches
  2. Mar 23, 2016 at 11:48 AM
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
  3. Mar 23, 2016 at 12:16 PM
    SjTacoSharks
    SjTacoSharks Well-Known Member
    Larry
    Boise, Idaho
    09 DCSB SR5 Sport
    God that is sooo sexy
    gordi[QUOTED] likes this.
  4. Mar 23, 2016 at 2:05 PM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
  5. Mar 23, 2016 at 2:53 PM
    ERMB
    ERMB Well-Known Member
    2002 Land Cruiser
    Sausage filled croissants for a faculty breakfast tomorrow!
    xJuice, la0d0g, vrod671 and 1 other person like this.
  6. Mar 23, 2016 at 2:58 PM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Now, I'm not an electrician, but that strikes me as incorrect...
  7. Mar 23, 2016 at 3:07 PM
    ERMB
    2002 Land Cruiser
    I got the idea from you remember ;)
    la0d0g, vrod671 and scottalot[QUOTED] like this.
  8. Mar 23, 2016 at 3:10 PM
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport 4x4
    Stock
    Gimme :drool:
    la0d0g, scottalot and ERMB[QUOTED] like this.
  9. Mar 23, 2016 at 3:13 PM
    ERMB
    2002 Land Cruiser
    Breakfast is served at 7 am sharp, classes start at 7:30
    vrod671[QUOTED] and scottalot like this.
  10. Mar 23, 2016 at 3:15 PM
    ERMB
    2002 Land Cruiser
    Well they've got cheese and maple infused sausage, so it's close :notsure:
    That maple butter sounds amazing though! Off to the grocery store in a few, I'm gonna look for that and make some for the kids this weekend.
    scottalot[QUOTED] likes this.
  11. Mar 23, 2016 at 3:21 PM
    vrod671
    Brandon
    2022 TRD Sport 4x4
    Stock
    You guys are killing me with the food talk.
    scottalot likes this.
  12. Mar 23, 2016 at 3:30 PM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Ahahahahaha nice touch with the extension cord. Good luck.
  13. Mar 23, 2016 at 3:30 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    I visit heaven pretty often
    Nickel and vrod671 like this.
  14. Mar 23, 2016 at 3:40 PM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Power was out.
    Had to get the furnace running. :D
    Generator in the garage at the other end of that cord.
    DEEVON911 and Drainbung like this.
  15. Mar 23, 2016 at 4:00 PM
    bethes
    bethes Señorita Member
    Beth
    Tulsa/Sand Springs, OK
    2011 V6 TRD Off Road
    Hey y'all. Today I did my first ever oil change and fluid check. It went well, except one thing. As I was checking fluid levels I started to pour the coolant into the reservoir and realized the reservoir has red in it, and my antifreeze is green.
    So of course I stopped pouring right away, a half cup or less of the yellow made it into the reservoir.
    The Internet says I should not mix red and green coolant. Should I drain the coolant reservoir since they're mixed now? Or just go get the correct coolant and finish filling it? Or drain it and use what I have?
    Thanks. I know this is kind of a silly question, but I'm a newb ;)
  16. Mar 23, 2016 at 4:11 PM
    la0d0g
    running for the hills
    For crawling not hauling
    My OCD would make me drain it but you can probably leave it and be fine.
    bethes[QUOTED] and scottalot like this.
  17. Mar 23, 2016 at 4:14 PM
    bethes
    Beth
    Good point. Does it matter if I use red or green as long as they aren't mixed?
  18. Mar 23, 2016 at 4:14 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I bet the coolant bottle says its compatible with all colors.
    bethes and scottalot like this.
  19. Mar 23, 2016 at 4:14 PM
    bethes
    Beth
    Wait. You're suggesting I read the bottle?!
  20. Mar 23, 2016 at 4:16 PM
    vrod671
    Brandon
    2022 TRD Sport 4x4
    Stock
    Some have different additives and might not react very well. I'd just drain and use one type to be safe.
