TW Live
  1. Jun 20, 2016 at 10:29 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    About the same power. Full size truck. Better gas mileage than "modern" V6
    steve o 77[QUOTED] likes this.
  2. Jun 20, 2016 at 11:06 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Never seen a 350 in a 4x4 that could clear 17-18, and I'm averaging 19-21 with my Tacoma right now.
    I think you've got more torque, less HP (210HP/300LB-FT or something like that, if I remember right?)
    Of course, that's when it was new. It's a safe bet that a few of the horses have escaped from the corral over the years.
    scottalot likes this.
  3. Jun 20, 2016 at 11:50 AM
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    255 HP's and 300 Torques. I'm getting 18+ with this pig. Could probably easily get 20 on the freeway. Tacoma never did better than 18 and averaged 15. All that and this pile has a quarter million miles.
    Noelie84[QUOTED] likes this.
  4. Jun 20, 2016 at 12:03 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    What year is that Chebby? Pre- 1996? OBDI emissions were very fuel efficient.
  5. Jun 20, 2016 at 12:07 PM
    Noelie84
    Noel
    Wales, Maine
    My cousin had a '96 with the 350/Auto that was a 4x4 extended cab and I don't think he ever saw it do better than 14. Dual flowmasters and a lead foot probably didn't help, but even highway driving when we took his truck hunting we were stopping for gas.
    Took a trip north in my work truck to pick up this year's bacon seeds last Thursday and actually averaged 18mpg's with a 32 year old Dodge 4x4. Had to check my math twice, lol.
  6. Jun 20, 2016 at 12:10 PM
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    98 with the Vortec 350
  7. Jun 20, 2016 at 1:56 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    I have a permit for the electrical upgrade at my house and I have a licensed electrician who is going to be rewiring everything from where the old panel is to where the new panel is going to be installed.
    So i just had to go to Crescent Eletrical Supply to buy all the stuff I needed and that hub is what the guy gave me when I told him what I had to do. He called it a hub and it has AL/EMT/IMC/RIGID stamped on it. The fitting itself seems to be the same thickness as the rest of the 2.5" piping I'm using. I was going to use that hub to connect to the riser in the ground which is connected to some waverib with a sure-lock coupling.
  8. Jun 20, 2016 at 2:23 PM
    SoFlaTacoTRD
    SoFlaTacoTRD TRD Taco'd
    SoFla
    2016 Tacoma TRD OR 4x4, ACLB, Quicksand
    I am glad to hear you have a contractor and permit while I can't speak for your supply house counterman but this is a hub...
    The photo you posted is of a compression connector which cannot be used if there are threads on GRC conduit, the threads must be cut off. We generally use hubs on top of meter cans where we have a mast extending to a weather head. On the bottom of cans and panels we use set-screw or compression connectors. In any case if this is the main panel and you use any type of metallic pipe/conduit you will be required to bond the connection between pipe/conduit and panel if you still have a concentric knockout remaining. A common and more economical solution to this would be to use schedule 80 pvc which is cheaper and being non-metallic does not require a bond at the connection. The NEC (NFPA 70) allows it but some jurisdictions do not.
    tacoguy67 likes this.
  9. Jun 20, 2016 at 3:30 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    From over the weekend..
    tacoguy67, Holloman, LUSETACO and 3 others like this.
  10. Jun 20, 2016 at 4:12 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Uhhhh. Wut? LOL.
    tacoguy67, EODTRD, LUSETACO and 5 others like this.
  11. Jun 20, 2016 at 4:28 PM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Employees must wash hands before returning to work?
  12. Jun 20, 2016 at 5:50 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    My favorite time. New tools!
  13. Jun 20, 2016 at 6:08 PM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    Jelly. Heard great things about those M18s
  14. Jun 20, 2016 at 6:14 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Not just the M18 but the fuel brushless tools are tits!
  15. Jun 20, 2016 at 6:17 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
  16. Jun 21, 2016 at 4:42 AM
    Donkeyfresco
    Donkeyfresco Well-Known Member
    2016 Tacoma TRD Off road DCSB
    None
    Aloha which Icon stage would y'all say is best in line with the OME BP51
  17. Jun 21, 2016 at 4:56 AM
    bubagump74
    bubagump74 SkiFreak
    Fred
    Montreal,Quebec
    2013 Trd OR
    NSA Pnl,US OFF ROAD winch mount bumper,Sirrius pods,Clazzio covers,Wheathertech mats, Pro Comp wheels,Image dynamics audio,leer cover,lights,bed mat,anti dark light...
  18. Jun 21, 2016 at 6:55 AM
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
  19. Jun 21, 2016 at 7:16 AM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    :burnrubber:
    LUSETACO[QUOTED] likes this.
  20. Jun 21, 2016 at 7:56 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    20 knots!! Live in key west from your salty sea dog ginger
