TW Live
  1. Jul 7, 2019 at 12:29 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    Put it in ice and/or torch it. The spindle shouldn't expand/constract as much as the adapter. I'm pretty sure it ain't AL though.
    Drainbung likes this.
  2. Jul 7, 2019 at 12:29 PM
    My Name is Rahl
    My Name is Rahl President of the Nunya Bizness fanclub!
    Rahl
    Central Ohio
    '18 TRD Sport & 040 FTMFW!!!
    No way to press it out?
  3. Jul 7, 2019 at 12:32 PM
    G.T.
    G.T.
    CONUS
    Trying to but there is very little to get purchase on due to the small diameter in the spindle.
    Tried heat with the MAP gas, shoved into shop freezer now to see if that helps.
    My Name is Rahl and Drainbung like this.
  4. Jul 7, 2019 at 12:53 PM
    My Name is Rahl
    Rahl
    Central Ohio
    Is the spindle roached? If it is, weld a long enough bolt onto it and use the bolt shank to press it out. :notsure:
  5. Jul 7, 2019 at 1:03 PM
    G.T.
    G.T.
    CONUS
    It’s a return core for @glorifiedwelder . My mate did a long travel swap recently and took our advice about doing gusseted spindles, but these little buggers won’t move, still in the freezer.
  6. Jul 7, 2019 at 1:14 PM
    My Name is Rahl
    Rahl
    Central Ohio
    Crud, so no welding. Is it just that you don't have the correct size of round bar to catch the little bit of small diameter that is there?
    mcharfauros and G.T. like this.
  7. Jul 7, 2019 at 1:27 PM
    G.T.
    G.T.
    CONUS
    Exactly. Once these come out some anti-seize is going on first.
  8. Jul 7, 2019 at 1:34 PM
    My Name is Rahl
    Rahl
    Central Ohio
    Anti-seize may need to have gone in first. :D Sorry I wasn't any much help.
    G.T. likes this.
  9. Jul 7, 2019 at 1:50 PM
    G.T.
    G.T.
    CONUS
    Got them out with the @deadhed61 freezer trick. Found a couple of nuts that fit perfectly in and could hit the inside of the bush and with a measured tap they each popped out.
    Thanks fellas, didn’t want to keep my mates truck here overnight. Now, where’s the anti-seize?
  10. Jul 7, 2019 at 1:53 PM
    My Name is Rahl
    Rahl
    Central Ohio
    Drainbung and G.T. like this.
  11. Jul 7, 2019 at 1:55 PM
    G.T.
    G.T.
    CONUS
  12. Jul 7, 2019 at 1:59 PM
    My Name is Rahl
    Rahl
    Central Ohio
    It comes in stick form now as well. No mess not so much mess and you get to use all of the product.
  13. Jul 7, 2019 at 4:05 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Get Outlook for Android<https://aka.ms/ghei36>
    G.T., la0d0g, 98tacoma27 and 2 others like this.
  14. Jul 7, 2019 at 4:09 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    My Name is Rahl likes this.
  15. Jul 7, 2019 at 4:20 PM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    96 FZJ80
    Slee, ARB, TJM
  16. Jul 7, 2019 at 4:25 PM
    mcharfauros
    mcharfauros IG: mcharfauros
    MO
    2017 Black TRD OR DC
    Dumb Truck Thangs
  17. Jul 7, 2019 at 4:54 PM
    ImpulseRed008
    Susan
    SC
    No, thank goodness. Just wanted a pic of Annie's tongue.
    98tacoma27 and My Name is Rahl like this.
  18. Jul 7, 2019 at 10:58 PM
    wilcam47
    wilcam47 Well-Known Member
    Arizona now!!!
    man you should have put this on the cook off open category in the food talk thread...
  19. Jul 8, 2019 at 3:12 AM
    AustinMada
    AustinMada Thinking About Tacos
    Austin
    2019 Tacoma TRD Off Road
    Just what the doctor recommended. Baumholder Germany
  20. Jul 8, 2019 at 10:12 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
