TW Live
  1. Jan 4, 2012 at 8:11 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    :thumbsup: Have that same cup! Use it daily!
  2. Jan 4, 2012 at 8:50 AM
    carcharias
    carcharias Giggiddy what what
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    Wait, whu...??? I just upgraded to ios 5.1. Is that what your iPhone is running? No one else has seen the little tipsy Jeep photo??
  3. Jan 4, 2012 at 8:55 AM
    mntbiker2008
    mntbiker2008 First I derp.. then I herp
    Aaron
    Cincinnati, OH
    93 Pick up 4x4 (sold), 10' Mazda 3
  4. Jan 4, 2012 at 9:04 AM
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit OReiley battery terminals Big 3 upgrade (0g wiring) 2012 Headlight swap HID kit (headlight 6k/fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails 2012 front grill/bumper cover w/ fog light and hood swap Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: XR Bilsteins Universal Air Suspension strut bag Custom UCA's DJM 4" rear drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs 4 Siria (Asco) 3/8" air valves 3 gallon air tank 1/4' air lines 90's Acura Integra door switches to air valves ViAir 450 air compressor Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Sick Speed 3 piece spike lug nuts Pepboys valve stem caps 1" wheel spacers all around Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" single Hifonics subwoofer 10" sealed angled box Katana shift knob
    how is the shock?
  5. Jan 4, 2012 at 9:05 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    angry beaver?
    Correct....well it's is repairable....just not recommended.
    Ask Ben he had more plugs in one tire then all of mine combined :D
  6. Jan 4, 2012 at 9:05 AM
    hellrazor004
    hellrazor004 Well-Known Member
    Rob
    09 DCSB
    I hover my wood stove between 400 and 600. Had it up to 650 the other day and was worried it would overheat so i backed it off. Good to know it can get that hot just fine though.
  7. Jan 4, 2012 at 9:11 AM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    Swing by, you can be the first to find out. I know i'm not gonna try it. :D
  8. Jan 4, 2012 at 9:12 AM
    07TacoRidah
    LMAO good thing I'm out in CA :D tried looking for a demo on it, keep finding the other one (the flashlight that shocks the user).
  9. Jan 4, 2012 at 9:22 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Time to put in work.
  10. Jan 4, 2012 at 9:25 AM
    Toyota Tech31
    Debary, Florida
  11. Jan 4, 2012 at 9:29 AM
    07TacoRidah
  12. Jan 4, 2012 at 9:29 AM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    If the tire is worn down more than 3/32's from new depth, buy 2 and put them on the rear. And not only will tire shops not touch anything with a sidewall puncture, they won't touch anything within about 1/2" from the sidewall in the main tread, let alone IN the sidewall. From Discount's site: http://www.discounttiredirect.com/direct/brochure/info/tmpInfoTireRepairs.jsp
  13. Jan 4, 2012 at 9:41 AM
    Toyota Tech31
    Debary, Florida
    Front or rear placement shouldnt matter, as long as they are on the same axle. To avoid any pull caused by uneven tread depth.
  14. Jan 4, 2012 at 9:44 AM
    BrettBretterson
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    Give me a minute and I'll find a link explaining why new tires should always go on the rear when only buying 2, FWD or RWD...and the reason for being on the same axle is for gearing issues, uneven tread depth's will rarely cause pull.
    ...Here you go. And this isn't just sales driven jargon, I've seen its' effect first hand quite a bit, the video on this page shows real world effects: http://www.discounttiredirect.com/direct/brochure/info/tmpInfoNewTireMounting.jsp
  15. Jan 4, 2012 at 9:46 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    got almost 60 hours on skyrim and havent played MW3 or the new Zelda yet...both sitting on the shelf
  16. Jan 4, 2012 at 9:48 AM
    NicNac22
    NicNac22 D.I.L.L.I.G.A.F
    Nic
    Wild and Wonderful
    95 V6 4x4 ex cab SR5 5sp PICKUP!!!
    fun stuff coming soon! New battery, radiator and CV joints and axles. Added some Rancho RS5000 shocks.
    :woot: rear shocks are here!!! Sent from my Samsung Transform?
  17. Jan 4, 2012 at 9:49 AM
    thebigk
    thebigk 6 Double 5 3 2 1
    Ken....
    Odessa, TX
    NOT TO BE CONFUSED WITH FLESHLIGHT!!! :eek:
  18. Jan 4, 2012 at 10:12 AM
    Toyota Tech31
    Debary, Florida
    This would be true had the Op not stated that he had pretty darn good tread all around.
    But in the case of replacing 2 new tires on one side of the vehicle (or thus the reason for always wanting to replae 2 at the same time), the vehicle would naturally want to drift/pull to the side of the lower tread.
  19. Jan 4, 2012 at 10:22 AM
    BrettBretterson
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    But you should never be matching tires by side, that is a mistake; you match by axle. If you're replacing 2 tires from one side, those 2 new tires need to be moved to the same axle, not left on one side of the vehicle. The only time tires should cause pull is by uneven(not mismatched) wear. Mal-alignment, cupping caused by worn shocks, lack of regular/frequent rotations, these are things that cause pull.
  20. Jan 4, 2012 at 10:24 AM
    07TacoRidah
    ROFLMAO!!!! wonder what person would confuse that
