TW Live
  1. Aug 18, 2012 at 8:29 AM
    jrzyshore
    jrzyshore Well-Known Member
    Scott
    SNJ
    2010 Toyota Prius TRD Offroad
    Icon extended travel coilovers and rear shocks, Dakar leaf springs, Toytec U bolt flip, extended length Icon 2.0 rear shocks, Timbren Bump stops ,TC UCAs, Street Taco (Beefedtaco) 1 1/2" CB drop, 4x Innovation DOM tube sliders with kick outs, some extended brake lines,ATO front skid plate, ATO trans skid, ATO Hi Lift brackets, 60" Hi Lift jack and a pine tree air freshener.
    Did you remove the spindle or just the upper ball joint?
  2. Aug 18, 2012 at 8:36 AM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    I don't know anything about 2nd gens, but on the 1st gens you just unbolt the spindle from the LBJ and swing it out of the way. No need to mess with that... whatever it is you're prying apart.:eek:
  3. Aug 18, 2012 at 8:41 AM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    Thanks man. It gets aligned monday, and I'm debating wearing these tires out, or putting new on...
  4. Aug 18, 2012 at 8:41 AM
    jrzyshore
    Scott
    SNJ
    I have done them before just not on my Tacoma yet. I usally remove the upper ball joint but the less you have to remove is better. Do you try a pry bar on the inside of the cv shaft it should be a pressure ring.
  5. Aug 18, 2012 at 8:42 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    If you've already pulled the two bolts from the LBJ, use a deadblow hammer.
    Hit the end of the axle inward with wookie strength.
    EDIT: Move the jack out of the way too. Let the whole suspension assembly hang free.
  6. Aug 18, 2012 at 8:44 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
  7. Aug 18, 2012 at 8:44 AM
    jrzyshore
    Scott
    SNJ
    I didn't see this I thought it would slide out of the spindle.
  8. Aug 18, 2012 at 8:45 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    :rofl:
  9. Aug 18, 2012 at 8:46 AM
    jrzyshore
    Scott
    SNJ
    :thumbsup:
  10. Aug 18, 2012 at 8:47 AM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    A rubber mallet usually works for me. Anything else usually deforms the end of the CV
  11. Aug 18, 2012 at 8:48 AM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
  12. Aug 18, 2012 at 8:48 AM
    Fightnfire
    Marysville, WA
  13. Aug 18, 2012 at 8:51 AM
    Madjik_Man
    Colorado Front Range
    Was doing my "morning thinking" when this guy ran across the floor.
    I'd say from the tip of his front legs to the tip of his back legs he was about 1.75 - 2.00" long. Scared the crap out of me... good thing I was assuming the position already
  14. Aug 18, 2012 at 9:00 AM
    Deathcure
    Deathcure Well-Known Member
    Wheeling WV
    12 Tacoma Off Road
    Found some thing cool looking*
  15. Aug 18, 2012 at 9:01 AM
    MTgirl
    Weesa
    Bob's secret mod lair
    :eek:
    Time to burn your house down.
  16. Aug 18, 2012 at 9:07 AM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    but put the big nut back on the shaft and use the hammer against the nut. dont dead blow on the threads, they damage easy.
  17. Aug 18, 2012 at 9:25 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    T-Rex 14RR
  18. Aug 18, 2012 at 9:28 AM
    Deathcure
    Wheeling WV
    12 Tacoma Off Road
  19. Aug 18, 2012 at 9:28 AM
    Deathcure
    Wheeling WV
    12 Tacoma Off Road
  20. Aug 18, 2012 at 9:30 AM
    Deathcure
    Wheeling WV
    12 Tacoma Off Road
