Tweeter delete
Discussion in 'Audio & Video' started by earling2, Feb 12, 2018.
  1. Feb 12, 2018 at 6:28 PM
    earling2
    earling2 [OP] Active Member
    Dave
    2010 Tacoma RWD 2.7 Auto
    Ok, I replaced the speakers in my 2nd Gen tacoma with JBL three ways. Bought the correct harness, the 6x9 adapter, etc etc--everything's good, works fine. The problem is that I need to get rid of the stock tweeters because they make the whole thing sound harsh. However, if I unplug them I get no sound out of the 6x9s. i have no idea how to fake out the wiring to think there are still tweeters there. Drawing a blank. Worst case scenario I could tear up the paper tweeter cones so no sound comes out but there's got to be a cleaner way to do it, I just don't know enough about electric things to figure it out.
  2. Feb 12, 2018 at 6:32 PM
    Minny Taco
    Minny Taco For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Dobinsons shocks and leaf pack - Level 8 MK6 wheels - 265/70/17 Goodyear Wrangler Duratracs load C - SPC UCA - Moog LCA - TRD Pro headlights - Bullet Proof Fab skid plate w/ Line-X - 3M Matte Black roof vinyl - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - MESO LED red/white map lights - Osram Super Bright H4 bulbs - Headlight Services upgraded wiring harness - Auxito LED reverse lights - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - AJT Design custom climate knobs - Center console organizer - Salex glove box organizer - 1" driver seat spacers - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Black LED third brake light - Ruff Tuff Kryptek Typhon seat covers - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights w/ lo-pro mounts - Subaru tweeters + Rockford Fosgate speakers - Thinkware F800 Pro dash cam - Stickers n shit
    Replace stock tweeters with better quality?
  3. Feb 12, 2018 at 6:34 PM
    earling2
    Dave
    Sounds great if you just cover the tweeters with your hands. The tweeters at this point just make redundant treble and midrange that's already supplied by the big speakers. If I'd known ahead of time I just would have gotten woofers and new tweeters.
  4. Feb 12, 2018 at 6:42 PM
    captainh00k
    captainh00k Well-Known Member
    Pittsburgh, PA
    2023 DCSB
    I believe you need to figure out which wires going into the tweeters and route them directly to the new speakers. The lowers speakers run thru the tweeters.
    I forget which wires, but I recall seeing it here while searching speaker upgrades.
  5. Feb 12, 2018 at 6:44 PM
    earling2
    Dave
    I think all I need to do is connect the black and the red together, but that seems a little weird to me. (black and red are what supply the tweeter but there's a white that goes to a capacitor to suppress the bass signal if I understand correctly. Not sure what the fourth wire is for.)
  6. Feb 12, 2018 at 6:54 PM
    earling2
    Dave
    So I changed my search parameters a little and came up with the answer, which is the following, if anybody's interested:
    "OK, so what I ended up doing was I took the harness on each door panel that connects to the stock tweeters, cut them at the connector, and then soldered together the like color wires."
  7. Feb 12, 2018 at 7:36 PM
    Do58
    Do58 Well-Known Member
    2015 white tacoma limited
    That’s what you needed to do. Input and woofer go thru that connector
