tweeter recommendations
Discussion in 'Audio & Video' started by EGtaco, Jan 20, 2010.
  1. Jan 20, 2010 at 7:45 PM
    EGtaco
    EGtaco [OP] Well-Known Member
    2009 Tacoma
    Going to change out my speakers finaly and need some new tweeters for the front door of my 2009. Any suggestions??? I have looked at crutchfield and a few other big box stores and no one carries just tweeters. What do you guys run if you dont have a component sets.
  2. Jan 20, 2010 at 9:12 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Check Madisound and Parts Express. They sell individual drivers.
    However, I have to ask what your plan is with the system as a whole and how you're hooking everything up.
  3. Jan 21, 2010 at 3:21 PM
    EGtaco
    2009 Tacoma
    I have 2 pairs of 6 1/2" for the doors. Going to replace the stock 6X9's in the front with 6 1/2s and wanted to replace the stock JBL tweeter int he front doors. I also have a 8' JL w3 to go behind the rear seat and the kenwood DNX8120 as a HU. I will probably run a small amp to power the front door 6 1/2 and tweeters. Thinkng maybe a 75watt X 2 channel amp for the front and leave the back door 6 1/2s powered from the HU which says it runs 22 RMS per channel i think. That shoul dbe enough to power the rear doors. DOnt need it booming but do want it to sound good.
  4. Jan 21, 2010 at 5:34 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Since you're planning on running the tweeters and 6.5" midbass speakers for the front doors off a two channel amp how are you going to crossover the speakers? Do you have a passive crossover to use with them? If you don't run a crossover you'll blow up the tweeters instantly.
  5. Jan 21, 2010 at 7:31 PM
    EGtaco
    2009 Tacoma
    good call never thought about that....still pretty new to the stereo stuff. I just wanted the tweete to increase the highs a nd make the sound a little "brighter" and since I am not running componets I thought this would be a simple job
  6. Jan 21, 2010 at 7:35 PM
    tacobell007
    tacobell007 Does that have the v6?
    Drew
    Westfield, MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, adjustable Bilstien 5100's up front, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Kenwood 350 watt amp, stickers, Better Built toolbox, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 33x12.5x17 General Grabber AT2, Fuel Off-Road Trophy d551 in 17x8.5, BHLM, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro Dry-S drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear plate with swing out and full size spare, SOS bolt-on sliders with kickout, 20" LED bar on main hoop, flush mount pods in rear plate bumper for aux reverse lights
    My dad has some Cerwin Vegas and they sound pretty good
  7. Jan 21, 2010 at 8:14 PM
    doodle66
    doodle66 Texas Taco
    Robert
    central tx.
    03 dbl cab blk
    deck plate mod, cold air scoop, K&N, fog light mod, aux. lights,
    i would say balance the front pair with a matched set with driver tweeter and crossover like boston acoustics or a less expensive route with the kicker ds component series. the boston sr or sl series only. all the others are low to middle line. the kicker ds series sound really good for the money, and will take what u giv. boston is about as good as it gets.
  8. Jan 21, 2010 at 8:36 PM
    ItalynStylion
    Steven
    DFW, Tx.
