tweeter upgrade
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Justyn98, Mar 27, 2017.
  1. Mar 27, 2017 at 6:06 PM
    Justyn98
    Justyn98 [OP] Well-Known Member
    Justyn
    West Virginia and Kentucky
    09 barcelona red tacoma trd sport DCSB
    Led pod fog light inserts, kn cold air intake, Bilstein 5100 with 2 inch coil combo and progressive AAL. Touchscreen pioneer stereo and infinity components with 2 kicker comp r10's and jones turbine exhaust
    What size tweeters do i need to buy to replace the junky factory ones?
  2. Mar 27, 2017 at 6:12 PM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    The tweeter mount is integral on the stock tweeter. So pick your favorite tweeter, get custom mounts that fit that tweeter, then bolt it in.
    Rambo54 and Norton like this.
  3. Mar 27, 2017 at 6:17 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    i went with some pioneer ones.
    https://www.amazon.com/Pioneer-TS-T...id=1490663744&sr=8-1&keywords=pioneer+tweeter
    a 3/4in wide 1/8th thick aluminum flat bar cut to size and 3 holes drilled (two to attach to door, one for the tweeter) n boom you are golden.
    FYI, Stock tweeter wiring is REVERSE polarity (something about making a larger sound stage....) either way, I wired my pioneer tweeters in properly (that is positive on the harness side / main speaker to positive on the tweeter) and called it good. Shit sounds great. Also i used the plug off the stock tweeter so i didnt have to cut the main door harness at all.
    MurderedTacoV2 and TegoTaco like this.
  4. Mar 27, 2017 at 6:22 PM
    Justyn98
    Justyn
    awesome thank you so much man im gonna probably go with the jbl ones!
    TXpro4X4 likes this.
  5. Mar 28, 2017 at 12:45 AM
    Dvst8r1K
    Dvst8r1K Night-Taco
    Greg
    2nd gen Black Tacoma SS 4.0l 4-dr 4x4
    1" Toytec body-lift, K&N filter, coolant by-pass, mesh cotton screen delete, TTBS, WeatherTech in channel visors, 2.5" Rancho full suspension kit, Oil Catch Can, Toyo 285/70 A/T-2's, 21.5" light bar in grill, blacked-out grill, de-badged entire truck; and again, more to come.....
    Is it JBL, or JVC that makes the P-Series (power) series speakers?? Hard to find, but my last set with no amp sounded superbly awesome!!!!
    Rambo54 likes this.
  6. Mar 28, 2017 at 4:33 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Your tweeters are wired out of phase. The capacitor used to limit the low frequencies to the tweeter inverts the sine wave, I.e. the positive half of the sine wave going into the capacitor results in a negative output to the tweeter.
  7. Mar 28, 2017 at 5:03 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Norton likes this.
  8. Mar 28, 2017 at 5:06 AM
    floodedkiwi
    floodedkiwi Well-Known Member
    Ken
    Naw'lins, Louisiana
    2019 GMC AT4
    Dog.
    I went with Focal Speakers from Crutchfield in the front and mounted the tweeters in the factory screen. Just be aware that you cannot buy that goofy little black plastic screen by itself if you mess up....
    timbobzimbob and Norton like this.
  9. Mar 28, 2017 at 5:12 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I have done a few of these on my own and have settled on bending a piece of metal strap into a U shape (with wings) to bolt into the stock locations. I use the strong 3M mounting tape on the back of the tweeter and stick it to strap. Keeps the stock look, no cutting.
  10. Mar 28, 2017 at 8:29 AM
    Rambo54
    Rambo54 TacomaBob
    Robert
    Eustis,FL
    2013 Nautical Blue Metalic Tacoma PreRunner DCLB
    Many !
    I went with Skar Speakers and tweeters all around ! Sounds badass and Great for a little over $200 Installed !
    I have paid that just for a pair of 6x9s years ago in the 70s-early 90s !and had to install my self,speakes have all came down ALOT !!!!!
  11. Mar 28, 2017 at 8:38 AM
    nd4spdbh
    SoCal
    the pioneer speakers were wired as stated in the manual of the speakers. Wire positive of the tweeter to positive of the main speaker. Maybe they accounted for this reverse polarity caused by the cap (i imagine they did).
    Rambo54 likes this.
  12. Mar 28, 2017 at 5:00 PM
    Larzzzz
    Larry
    MA
    Where is/was the factory capacitor? Is it part of the harness or part of the tweeter? Same question for the new tweeters.
  13. Mar 28, 2017 at 8:43 PM
    nd4spdbh
    SoCal
    factory tweeter had a cap... forget which side it was on as far as positive or negative, but it was glued to the tweeter itself.
    those pioneers i linked to have a cap inline to the tweeter.
    But just note, like stated, the negative (black colored wire and marked negative on the tweeter) on the STOCK tweeter (tweeter side of the plug) went to the positive (harness side) for the main speaker likely for reasons stated above.
    All conventional setup of aftermarket speakers show that you wire your positives together. Because likely with an inline cap like the pioneers i linked to this reversal of polarity after the cap has been taken into consideration and things have been marked accordingly. So just make sure that the positive of your aftermarket tweeter goes to the positive on the harness side irrespective of the coloring / markings of the original tweeter.
    Rambo54 likes this.
  14. Mar 28, 2017 at 9:47 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    +1 for Focals. Got a great deal on their PS 165 V1 2-Way Component Kit.
    Didn't plan ahead well enough to get ********* tweeter mounts as recommended by @Torspd, so I went with a home-spun mount solution similar to @nd4spdbh's.
  15. Mar 29, 2017 at 3:56 AM
    Larzzzz
    Larry
    MA
    The factory wiring took the phase reversal into consideration if the tweeters negative wire comes from the positive wire of the other driver exactly for the reason I stated.
    If the cap on both the factory and replacement tweeters are terminated to the same terminal respectively, I stand by what I said.
    The only way around that, for wiring + to + and - to -, would me to get 2 caps, twice the value needed and wire them in series or end to end.
  16. Mar 29, 2017 at 8:08 AM
    nd4spdbh
    SoCal
    what im saying is that the pioneer tweeters label the wires positive and negative and say to hook to positive and respective negative of the main speaker, they took the phase reversal into consideration from the pioneer factory and have actually attached the wire labeled positive to the negative side of the tweeter n visa versa so you dont have to do it.
    Benny123 and Larzzzz[QUOTED] like this.
  17. Mar 29, 2017 at 8:20 AM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    I still have my factory tweeters (swapped out my other speakers years ago). Can the new tweeters be connected to the standard coaxial speakers with no issue?
    I seem to remember some issue, or reason I didn't do it when I replaced the other speakers. It may have been the way that they mount to the door.
  18. Mar 29, 2017 at 8:33 AM
    CWMcTaco
    CWMcTaco Well-Known Member
    Dallas
    2011 TRD
    Icon all around
    I have factory JBL system in my 2011 Taco. Can I just swap aftermarket speakers in place of the factory ones? I'm told the JBL amp does all the cross-over and the speakers have to be 2 ohm. The guy at Cartoys told me I would need to tap into the HU speaker output and add a LOC and amp...which adds about 3-500 bucks. I'm not trying to make a high power system, just want better speakers. After listening to some Focals (component type in front and coax in rear) I couldn't believe how much better they sound.
  19. Mar 29, 2017 at 8:36 AM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Mine are jbl
    Sound good but be carefully if you have Bluetooth.
    People's flat voice have popped mine
  20. Mar 29, 2017 at 10:14 AM
    Larzzzz
    Larry
    MA
    Ah, that makes much more sense. I lost it in translation.
