Tweeters in a 98-00 1st gen?
Discussion in 'Audio & Video' started by Madjik_Man, May 22, 2012.
  1. May 22, 2012 at 8:52 PM
    Madjik_Man
    Madjik_Man [OP] The Rembrandt of Rattle Can
    Colorado Front Range
    I know the 01-04 have tweeters in some of them.
    Was wondering if anyone with a 98-00 has tweeters in theirs and where they might have mounted them.
    Thanks.
  2. May 22, 2012 at 8:56 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Custom pillar mounts are pretty popular.
  3. May 22, 2012 at 9:06 PM
    Madjik_Man
    Just drilling out the pillar and flush mounting a tweeter or just surface mounted?
    Do you mount them as close to ear level as possible?
  4. May 22, 2012 at 9:09 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Normally, remove the plastic cover and fabricate a glass housing to hold the tweeter.
    (and now I'm trying to remember if the early 1st gen has plastic covers on the A-pillars)
    They're normally mounted just above the dash, aimed either across the dash, or maybe at a slight angle, but not directly at the driver... the left channel will overpower the right.
  5. May 22, 2012 at 9:11 PM
    Madjik_Man
    Thanks Rich
    Yeah, they are plastic.
    And you need a housing for the tweeter? Can't just have them screwed into the pillar without them moving around or falling off lol?
  6. May 22, 2012 at 9:13 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    As close to ear level is best. Our 01-04's have tweeters in the door off-axis, not pointing directly at the listener.
  7. May 22, 2012 at 9:22 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    You could just screw the cup into the pillar, but it would look like shit :D
    Tweeters are normally sealed-back so ya... it doesn't need an enclosure, but it looks a lot nicer and A-pillar housings are not hard to make.
    Cut a ring that the tweeter fits, cover the plastic with saran wrap, jig the ring where you want it with popsicle sticks, and lay the glass on so it looks nine.
    Sand, prime, fill, sand, prime, fill, sand... then shoot it with VHT (they make paint that matches interior plastics, though it's a little more flat than stock).
