Tweeters
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dsa51380, Apr 10, 2024.
  1. Apr 10, 2024 at 5:09 AM
    Dsa51380
    Dsa51380 [OP] Member
    Shane
    2020 TACOMA TRD OFF-ROAD
    Hello all! Question... I installed some coaxial speakers in my front doors and now I'd like to replace my factory tweeters. I have a 2020 off rd Tacoma which I've heard this model shares the signal between the tweeter and door speakers. My amp is 100 rms per channel and my speakers are 100 rms so it worked out. My question is if I get new tweeters, will I need a bigger amp or door speakers with a lower rms or would it work just fine? The amp pushes all 4 door speakers. I kept my factory stereo so I used a harness.
    Also.. if I were to get component speaker, would I have to run new wire to each speaker and need a bigger amp so I can run it to the tweeters individually?
    Thank you all!
  2. Apr 12, 2024 at 3:08 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
