Tweety Noise, constant when clutch engaged
Discussion in '1st Gen. Tacomas (1995-2004)' started by Crashmo, Sep 12, 2009.
  1. Sep 12, 2009 at 9:20 PM
    Crashmo
    Crashmo [OP] Well-Known Member
    Captain Dude
    Portland
    Was 03 TRD, Now 07 TRD
    Brush guard and Bed Storage and Karr Alarm.
    Any help very appreciated. When my clutch is engaged (power to the road) my engine/tranny make a noise that is like a constant tweety bird. I hear it as I drive near curbs or walls with the windows open. It is loud enough to notice at all times.
    It does go away when the clutch is disengaged (pedal depressed).
    It sounds like what you'd expect to hear with a belt slippage problem, but I'm pretty sure the belts run continuously and are not affected by the clutch engagement.
  2. Sep 12, 2009 at 11:16 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Sounds like maybe throw out bearing, how's the release when you take off? Is there any slippage? Oh yeah, does it make the noise sitting still in neutral with clutch in/out ?
  3. Sep 13, 2009 at 1:05 PM
    xsvtoyz
    xsvtoyz Well-Known Member
    AL
    Oklahoma
    03 Pre-Runner Inprogress
    HID (ACA)/ Web cams/ Header/Full Custom exhaust/ K&N FIPK II/SuperCharger
    its either the throw out but you describe it in reverse of what I believe. more likely its the fork that holds the throw out. when its slack it vibrates and creates a squeal type noise. try lubing the fork pivot point and where the slave pin hits.
  4. Sep 13, 2009 at 6:21 PM
    Crashmo
    Captain Dude
    Portland
    Thanks for the replies.
    The release is fine, no slippage. It only has 43k miles, I can't believe I've abused the clutch bad enough to see wear this soon. Primary driving is road.
    Yes, it makes the noise after it's warmed up while sitting still in neutral. As long as the clutch pedal is out, it makes noise.
  5. Sep 14, 2009 at 10:07 AM
    xsvtoyz
    AL
    Oklahoma
    try the above
  6. Sep 14, 2009 at 11:01 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    x3
    I think it is the throw out bearing
  7. Sep 14, 2009 at 12:44 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    :cool:Yeah I'm still thinking throw out bearing, possibly weak or slightly bent finger on pressure plate but doubtful, that is really low mileage for this shit to start happening, but seeing how that noise is consistant out of gear ,sitting still my money is on the bearing.
  8. Sep 14, 2009 at 4:03 PM
    takern
    takern Well-Known Member
    Tanner
    Virginia
    03 TRD Offroad stepside
    Deckplate mod, sliders, uniden cb, toolbox, dakar leaf pack, in search of coilovers, 255/85 16 bfg m/t waiting to go on
    i had the same issue and noticed it about 10k miles ago. i lubed the fork pivot point and it shut it up for like 3 days, then came back. its not really doing any damage, so just turn the music up. just to be sure though, press the clutch until there is just barely any pressure and see if it stops
  9. Sep 14, 2009 at 7:52 PM
    Mootsman
    Mootsman Active Member
    Gunnison, Colorado
    02 Tacoma SR5
    3" Fabtech Lift
    Throw out is my guess, but what I really wanted to say is nice boats! Did you build those? We have Current Designs Solstice GT's. Now back to the subject.
  10. Sep 15, 2009 at 11:23 AM
    Crashmo
    Captain Dude
    Portland
    Yep, we finished them in July after 2 1/2 years of mostly procrastination. They are One Ocean Kayak Storm and SLT. Now we're having fun with them and nobody notices the truck anymore. Hmmmm. :cool:
    Thanks for all the good intell. I'll get on it as soon as my other half brings it home. She's on a weeklong foray in southern Oregon known as Cycle Oregon.
