Twetters for 05 tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05TacomaGirl, Dec 25, 2022.
  1. Dec 25, 2022 at 8:25 PM
    05TacomaGirl
    05TacomaGirl [OP] Well-Known Member
    Tampa, FL
    2005 Toyota Tacoma prerunner V6 SR5
    Would anybody happen to know the size of the tweeters that are in a 05 Tacoma prerunner?
  2. Dec 25, 2022 at 9:19 PM
    mk5
    mk5 Probably wrong about this
    SoCal
    '05 access cab 4x4
    Sorry, I don't know the answer to your question. But, I can tell you that they're mounted to the door in a way such that you can mount a wide range of tweeters in this location -- I wouldn't worry about trying to match the size to OEM. There is plenty of space, both in terms of diameter and depth, to fit nearly anything that would qualify as a tweeter. You just need an appropriate bracket -- which is something you can easily make yourself.
    Here's a post where I discussed replacing my speakers last year. You can see the new and old tweeters and how they were mounted. Both were aftermarket -- no idea what the OEM speakers look like.
    I bought the new speakers from Crutchfield, and they included mounting brackets that made it easy to install the tweeters that came with the speakers. It's just a piece of plastic with mounting holes at the correct locations. You use a hole saw to drill a hole in it, for whatever size tweeter you have.
    Merry Christmas!
    FishaRnekEd likes this.
  3. Dec 25, 2022 at 9:35 PM
    MGMDesertTaco
  4. Dec 26, 2022 at 1:34 PM
    yeahdude97
    yeahdude97 Well-Known Member
    I also recommend crutchfield, they have excellent customer service and pretty much anything you need audio related
  5. Dec 26, 2022 at 1:57 PM
    Danke5305
    Danke5305 Well-Known Member
    2013 tacoma prerunner
