Twin Stick Transfer case
Discussion in '2nd Gen. Tacomas (2005-2015)' started by badger, Sep 27, 2012.
  1. Oct 10, 2012 at 9:54 AM
    #101
    shemp
    shemp Well-Known Member
    I suspect you're trying to be funny, but that is actually an easy one. I would use a pull-push cable since it would be a whole lot simpler than running a lever relay system.
    However, electric is probably the best way to operate an ADD. Yours bummed out, just bad luck. Basically, it is a lot easier to seal the electric unit. Relays and cables are more prone to problems with ice when located down under the front like the ADD.
  2. Oct 10, 2012 at 9:56 AM
    #102
    Wicked 2007
    Wicked 2007 Well-Known Member
    Bay Area, CA
    2007 Tacoma AT DC SB 4x4
    2007 Tacoma Double Cab SB 4WD - Auto -TRD Off Road - Icon Billet UCA - 8" ORI Front Struts - Bilstein 5100 11" RCD Shock - AllPro Expo Springs - Demello Sliders - Tom Woods 1 Piece Driveshaft - 16x8 Mojave Teflon Rims - Locker Mod - Locker Guard - 35" MT MTZ's - ARB Bumper - Warn 8000 winch w/synthetic line - All-Pro Front Skid/Transmission Skid/Rear Armor - ARB Front Locker - Nitro 4.56 gears - Marlin 4.7 crawl box - Twin Stick FJ t-case - ATO high clearance rear bumper
    i dont think he was joking. its a valid issue once they burn out although i dont hear a lot of them burning out. when they do its not cheap like $300 or some god awful cost...
  3. Oct 10, 2012 at 9:57 AM
    #103
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    ok, now this is just trolling since the ADD actuator is a problem on these trucks and no one makes a cable system.
    these problems all over TW and other toyota forums. Plus, two people in the same area with a lot of snow/ice/east coast in general have had their's go out pretty much at the same time
  4. Oct 10, 2012 at 10:04 AM
    #104
    shemp
    I wouldn't expect anyone to want to invest in something that doesn't benefit them. Junk is a harsh word, and I'm sure you agree that if this worked exactly as I claim, it wouldn't be junk -- you would not be investing in junk. However, it also wouldn't solve a problem that couldn't be deal with differently. In other words, either way it won't do you any good since you can achieve the same thing differently.
    Nor would I pay anything to provide physical proof of this to the internet. Unlike some, I'm NOT SELLING ANYTHING. I don't give two flying fu**s if you believe me or not, because even if I did prove something, doing so doesn't benefit me.
    So here we are.
    It isn't worth anything to you to prove me either right or wrong, and it isn't worth anything to me to prove myself right.
    Now if somebody offered to pay me some substantial amount of money to provide proof of concept or final design specifications, my position might change, because then there actually would be something in it for me. All you've offered me is the chance to break even, assuming that you are trust worthy, otherwise an expense with no actual reward. Just what AM I going to do with a spare transfer case?
  5. Oct 10, 2012 at 10:04 AM
    #105
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    It's about time you guys figured it out.
  6. Oct 10, 2012 at 10:07 AM
    #106
    shemp
    In that case, the best approach to the ADD might be to upgrade it to higher quality components rather than replace it with levers and cables.
    It would be interesting to see what the point of failure is on them, maybe they could be disassembled and repaired or improved without an overly substantial redesign.
  7. Oct 10, 2012 at 10:11 AM
    #107
    shemp
    See my previous reply. Failures don't mean that it is the wrong approach, just that something about it is flawed in execution.
    One vehicle I had used air pressure to operate the ADD. The electric air pump was under the front bumper at the front of the car, right where lots of salt and water would hit. It got flaky and eventually failed, so I removed it, took it apart, cleaned it out, replaced all the wires, sealed it up really well, and reinstalled it under the hood behind the battery where it was far less subject to salt spray. It never gave me another problem for 5 years until I sold the car.
  8. Oct 10, 2012 at 10:13 AM
    #108
    Large
    Large Red
    So why even say anything? UMAD? Someone is offering you a free Tcase to prove everyone wrong. If you manufacture this mock up and works as stated you could potentially have serious money at your fingertips, no?
    :stirthepot:
  9. Oct 10, 2012 at 10:14 AM
    #109
    shemp
    PM'ed ya.
  10. Oct 10, 2012 at 10:16 AM
    #110
    Large
    Large Red
  11. Oct 10, 2012 at 10:19 AM
    #111
    Wicked 2007
    Bay Area, CA
    because 1 of 2 things will happen:
    1) won't work
    2) if it does it will be so cost prohibitive to market with the alternatives out there it will be a waste of time which i think he has realized
    either way pitching theory on re-inventing a t-case is useless and should stop. sure anything is possible with time and money - but sometimes you have to ask your self why? and is it worth it?
    In this case the answer is no. so he needs to either do it or let it go... the ADD issue or getting manual hubs, that's of interest to a lot of people...
  12. Oct 10, 2012 at 10:20 AM
    #112
    shemp
    Actually, no. I wouldn't have any significant money at my fingertips. The problem is that (1) would be in competition with Wyatt, who offers a product that achieves the same objectives, (2) the market for this modification is EXTREMELY small, (3) I'm not in the business of manufacturing offroad equipment, in fact, I'm not in any kind of manufacturing business at all. All of my component fabrication is for personal hobby only. (4) Where would I come up with that "free" transfer case? The deal offered was that he would buy the modified case back from me, hence, I do not get to keep it unless it is trashed, or would get saddled with it if he didn't hold up his end.
    I speak about this subject because it is fun to consider alternatives to what there is right now. Because I appreciate an intelligent discussion, for those who are engaging in it from an intellectual point of view. Mad? No, of course not.
  13. Oct 10, 2012 at 10:22 AM
    #113
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    so for the guys that switch over to the FJ T cases, what are you doing with your old taco t case?
  14. Oct 10, 2012 at 10:22 AM
    #114
    Wicked 2007
    Bay Area, CA
    no you keep it if it works and i pay you back. im not asking for a free manual tacoma t-case back for your refund. you only dont get your money back if you dont do it or it fails.
  15. Oct 10, 2012 at 10:22 AM
    #115
    shemp
    Regarding (2), I never once suggested that it would be cost effective. I only suggested that it would be POSSIBLE. I don't, however, believe that it would cost nearly as much as people are suggesting.
    And thank you, for finally agreeing that yes, it is indeed possible.
  16. Oct 10, 2012 at 10:22 AM
    #116
    Wicked 2007
    Bay Area, CA
    a shiny paper weight in the garage thats for sale :)
  17. Oct 10, 2012 at 10:23 AM
    #117
    shemp
    In that case... it still doesn't help me since I don't need one.
  18. Oct 10, 2012 at 10:25 AM
    #118
    Wicked 2007
    Bay Area, CA
    the key to my statement - time and money. I think a lot of things are "possible" if you have an unlimited supply of both. but without it, its not possible... make sense?
  19. Oct 10, 2012 at 10:25 AM
    #119
    shemp
    PRERUNNER + SAS!!!!
  20. Oct 10, 2012 at 10:25 AM
    #120
    shemp
    Of course that makes sense.
